Question about Whirlpool ACP102PS Portable Air Conditioner
It is not cooling like it used to. We have had it for a year.
  • Whirlpool Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 30, 2010
Refrigerator not cooling all of a sudden
Most refrigerators do NOT cool all of a sudden, but rather gradually! If you need to cool something all of a sudden, you should consider use a freeze spray of some sort!
May 12, 2017 | Refrigerators
Engine fan stays running all day . it just started ,
What make , model and year vehicle ? You mean cooling fan's for the radiator . Some makers use a module to control the cooling fans others use relays . Looking at a wiring diagrams would show control componets . Relay contacts could be stuck sending constant B+ voltage , keeping fans on , same with a control module .
Jan 24, 2017 | Cars & Trucks
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
Had unit for 4 years do not use it awhole lot put
Good job, on cleaning the air intake filter. Some folks overlook that. Since that helped some, I believe you need to clean a little further. Like the cooling coils and the cooling fins for the compressor. But, before attempting any cleaning turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet.
You can clean the coils with warm water and liquid dish washing liquid,. Rinse and dry thoroughly. When dry, apply a light coating of WD40.
The fins can be cleaned using an old toothbrush and a vacuum cleaner that has a hose and brush attachment or crevice tool.
Completing this Annual Type Maintenance should provide significant results.
Jun 21, 2011 | Haier ESA3125 Wall/Window Air Conditioner
Laptop shuts down on its own constantly. Have had for two years but only used for about a year because of problems. Gateway M series AMD Turion processor 64 2 gb 2 mg 32 bit operating
If heatsink is very hot then apply thermal grease between the processor and the heatsink or you can test if it's cooling problem by cooling with an external, powerful cooler.
Sep 06, 2010 | Gateway (8008625) Cooling Fan, Heatsink...
What antifreeze do i put in a 2003 jaguar x-type?
Dex-cool type, the orange anti-freeze.
May 16, 2010 | 2003 Jaguar X-Type
RUNS BUT DOES NOT COOL TOO WELL.
if the compressor runs for a short time only it could be overheating due to a lack of refrigerant i would suggest finding a contractor who specializes in hampton bay to take a look at it
Jul 29, 2009 | Hampton Bay HBLG5004 Air Conditioner
Re: Dex-Cool in 1999 Lumina
The major reason for using dex-cool is that antifreeze is often neglected as a service item. If neglected, it becomes acidic over time which is particularly important with the use of aluminium in most major components which are served by antifreeze. Acid causes etching and premature failure of gaskets and permanent damage to blocks, heads and especially the radiator and heater core, which are not vert thick to begin with.
Since "normal" antifreeze acidifies faster than does dex-cool, mixing both together causes a change in breakdown rate...the more "normal" coolant added, the faster it breaks down.
Both coolants do not react chemically with each other and therefore retain the same ability to prevent boil over and freezing.
In reality, normal coolant can be used with little or no effect on components, provided that you change it every year. (that's where the EPA gets involved) They do not want people dumping this stuff into the ground, so they push for extended service intervals. Since dex cool has a longer service life, that's what they want you to use.
As far as how you chasnge the coolant, it is always a good idea to flush system during a change, regardless of antifreeze type. This removes solid particles which can plug radiator core. Radiators are much smaller than their older counterparts. Loss of even a small portion of cooling area can cause overheating. Engine running temps are also higher than older vehicles (heat=power output). Therefore most systems have a much smaller margin of error than before. What I find though is that regular flushing can also be bad for the system as the chems eat away at metal components in order to clean. I recommend regualr or dex cool antifreeze systems be flushed with water only, once a year, but retaining what you removed and filtering it through a coffee filter, using it during the year to "top off" the system. To retain effectiveness of coolant, use a hydrometer to check concentration, adding new coolant to bring reading to proper protection level.Then, every three years, do a complete chem flush and change entire batch. This keeps your system clean and the epa happy!
Dec 17, 2008 | 1999 Chevrolet Lumina
Heats, but think cooling fan may have stopped
If the cooling fan is not on, the magnetron can be destroyed.
It will have a full one-year warranty, then probably a 5-year warranty on the magnetron.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
I would contact them right away.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 19, 2008 | Microwave Ovens
Whirlpool ACP102PS Portable Air Conditioner Logo
292 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
