Question about Garmin Astro 220 GPS
I have busted the glass on my astro 220 and the glass has puntured the internal screen. i need to know what to do about getn it fixed. i can not get any one on the phone they put me on hold for 15 minutes and never got to me. it is 6 months old. ihink the glass is a verry bad idea for sportsman like myself . glass is not durable. i dont know how it got pusted. i think something needs to be done this is not good.
Tip
Fixing the glass on cracked screens.. LCD or Plasma
Ok, now this tip is a bit out-there bt.. here goes.. I have found this to actually work... well, infact. With limitations.
We have all heard or seen the "Wii Screen".. lol Where the user of the Wii controller.. dosen't, control it, I mean.. no they let go, it slips out of thier hand and shazam.. ya got a busted TV screen.
OK well there is a repair that will sorta fix and maybe even make it watchable, but ONLY if it isn't too big and hasn't actually cracked the Element behind.
Get in touch with one of theose car windscreen repairers, you know the ones that fix cracks in auto windows, and are "optically difficult to detect" sic.
Well if ya can persuade the dude doing it that Car.... TV ....wats the difference, still Glass, then ya just might get an acceptable Crack Fix depending.. but it is worth a try.. it does work..
on Jan 18, 2010 | Televison & Video
How do i change language to greeks my astro 220?
You could try this link to the manual, this may help you!
http://static.garmincdn.com/pumac/Astro_OwnersManual.pdf
Nov 29, 2014 | Garmin Astro 220 GPS Receiver
My Garmin Astro 220 will not pick up collars dc30 or dc40 outside 50-100 yards. I have updated all to newest 4.0. still not working. Any advise I have tried everything!
Try this:
  1. Power your Astro 220 ON
  2. Press DOG button
  3. Press MENU button
  4. Select DOG LIST
  5. Select the name of your DC 30 from the list
  6. Select SHOW INFO
  7. Press MENU
  8. Select CHANGE COMM. SETTINGS
  9. Choose OK
  10. Change your update rate to 5, 10, or 30 seconds
  11. Choose OK
If your update rate was set to 0 seconds, changing it to 5, 10, or 30 seconds will now allow for your DC 30 to communicate consistently with your Astro 220.
Aside from that, most problems with transceiver range relate to background interference, antenna/transmitter damage, and battery life.
Nov 17, 2012 | GPS
Astro 220 screen problem
you have a dead battery get a bigger memory chip
Aug 25, 2012 | Garmin Astro 220 GPS Receiver
Drivers door window replacement
Door glass bursting usually occurs due to heavy impact while closing the door or if the car is left in over heated environment. Some time it may occurs due to high beat of music system also.
Replacement of the window by self is not more complicated. You need to remove the door trim panel and other electrical connection from the doors.
Then clean the busted debries from the door thru' a vacuum cleaner. Purchase the right spare glass from the market. Remove the glass rail fittings from the position & fix the glass in the guide rails, then refix all the rails in position.
Put back the electrical connections & door trim in it place.
Jun 05, 2010 | 2001 Hyundai Elantra
My 1997 astro van is using alot of gas what could
You may need a tune up, spark plugs and plug wires. I would also consider replacing the fuel filter, if it has been replaced. Also check the air filter.
May 03, 2010 | 1997 Chevrolet Astro
My astro 220 does not extend out beyond 800 yards. It used to get a better range.
I have several of these units had two lately that the anttena had been over tightened and broke the solder inside the unit loose may be what is going on with yours
Nov 09, 2009 | Garmin Astro 220 GPS
Garmin astro 220 gps dogtracker
The antennas on the dog sender units had been over tightened, which resulted in the units internals being twisted and damaging the batterywiring. An easy fix once the units were disassembled and a lesson to be learnt: DON'T OVERTIGHTEN THE ANTENNAS ON THE DOG SENDER UNITS.
Apr 22, 2008 | Garmin Astro Combo Unit GPS Receiver
Bad Tires
Qinny buzz slime prevention tyre prevention essentials on e/bay at the mo for £4.49 + £2.00 p/p you may find you do have a small punture on the tyre can easily happen so this stuff will prevent any other punture in the future.. billy
Mar 13, 2007 | Quinny Buzz Jogger
Garmin Astro 220 GPS Logo
76 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
