Question about Just Flight C-130 Hercules (Add-on for CFS2 & Flight Sim 2002) for Windows
I installed C-130 Hercules in the FSX folder. When I click on C-130 to play, it shuts down all of FSX. Using Vista. Any help?
I have a geforce FX5500 256 AGP video card and need window 7 or a driver compat with Direct X9. the default driver shuts down to a blue screen (memory failure) and re boots with any attemp to play back any...
The newest driver available for your graphics card is designed for Windows Vista, but it should work with Windows 7. That does not necessarily mean that it will. I have included a link to download the driver below.
http://www.chipdrivers.com/download-get/454/130/12/
Hope this helps. Thank you for using FixYa!
Apr 06, 2011 | Palit Microsystems GeForce FX5500, (256...
FSX installed and activated easily (3 times) but no icon on desktop nor entry in "all programs" or MS Games. FSX plays after activation until I close program. Then cant be found.Can you help?
try to search it at program files. maybe at installation start menu folder or desktop icon didn't created but the program already installed.
open 'add or remove programs' window. if your game are listed in there, then your game is already installed at the computer. open C drive (where is windows installed) go to program files folder and search your game folder. if you find it then search the game application (.exe) right click and 'send to desktop'.
if your game is not listed in 'add or remove programs', then u need to reinstall the game. maybe there is problem with your VGA or RAM that makes the game erased after you playing the game. or maybe u have your computer 'deep freeze' program and you installed the game at frozen condition.
hope this useful.
Feb 18, 2011 | Microsoft Flight Simulator X
FSX = ****!
It sounds like a RAM issue. FSX needs a minimum of a dual core processor, a good quality graphics card (512Mb min) and 4Mb ram. The "not responding" is caused by the PC having to try to get a large amount of data into a small amount of ram, or the processor is struggling to cope.
Feb 25, 2010 | Microsoft Flight Simulator X for Windows
I successfully installed fsx but cant find the file to play it
Okay. Go to the FSX directory - C:\Program files\Microsoft games\FSX and locate the FSX.exe icon. Using the nouse, right-click the icon, and keep the right mouse button down and drag the icon to the desktop, then release it and choose "create shortcut here" from the fly-out menu. That's it. Then it will add an icon on your desktop which you can use aas normal to play it. Enjoy
Dec 31, 2009 | Microsoft Flight Simulator X
I can not install easycap driver.
I also just received my Easy Cap today (for a 64-bit Vista PC) and a little hunting online revealed the following web page which has a link to some drivers for Vista 64-bit:
http://dekonass.no-ip.biz/?p=462
The link is just under the picture. Worked for me.
Good luck
Jul 16, 2009 | Ulead Videostudio 8 for PC
How can get glass theme
http://www.crystalxp.net/galerie/en.id.130.htm
Jul 10, 2009 | Microsoft Windows Vista Ultimate Edition
FSX Free Flight shuts off
I had this Problem It seemed to fix it when I ran the game in Compatibility with Windows Xp SP2 and Ran as administrator
To do this Right Click the Icon
Got o Properties
go to Compatibility tab
Click the Box That says "run this program in Compatibility mode for:"
and Windows Xp Sp2, Should be automatically selected
And at the Bottom Under "Privilege Level"
click Run as an Admin
Jun 02, 2009 | Microsoft Flight Simulator X for Windows
Problem with FSX Demo setup
You need to find the directory where it has installed, usually in C:\program files\Microsoft games\FSX and then locate the .exe file. Right-click the mouse over this icon, holding the right button down, drag the icaon onto the desktop, release the mouse button and when teh small menu appears choose "create shortcut here" option.
Then you can start the program using the new icon on your desktop. As for playing it, you need to read the manual as it would take too long here to explain it. Good luck
May 03, 2009 | Microsoft Flight Simulator X for Windows
D-Link DWA-130 running Vista
OK!! I figured it out!! Ok you need to go to the Dlink web site, cursor over to the tech support tab, on the drop down select DOWNLOADS, enter your Dlink wireless adaptor version(you'll need the box for these steps), ok now in the new window click downloads, choose and download the 130 one not the beta version, have a flash usb ready and save all downloaded files to ur usb flash, next insert your usb flash on ur laptop, open my computer select ur removable drive and double click the dlink software, after you do this it should bypass that prompt screen and you'll be able to continue your setup for your Dlink wireless adaptor.........hope it works for you cause it worked for me.....
Aug 30, 2008 | Computers & Internet
MP110/130 drivers for vista
You can download the drivers from Canon. Click on driver downloads and pick the Vista driver.
MP110
MP130
Jan 24, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Just Flight C-130 Hercules (Add-on for CFS2 & Flight Sim 2002) for Windows Logo
Top Just Flight Video Game Consoles & Games Experts
James Wishart
Are you a Just Flight Video Game Console and Game Expert? Answer questions, earn points and help others
