Yes you have a bab pump if you want i can get ya one cheper than what most pepole can shoot me a e mail with your phone number and ill callya and price ya one tthanks mickey
And how exactly do I shoot you an email?
send it to [email protected]
I have the same unit. Work great when you get the hang of it. First thing is to COMPLETELY purge air from the system or you will get a weak spray. Trick there is to let the water run thru the system with the wand trigger on BEFORE starting the engine. Let the water run a good 10 or more minutes. Once the engine stops after it warms up, it will be hard to start again because of internal water pressure. Open the wand trigger again (wedge something in the handle to keep it open) while you yank the pull cord - but keep your foot on it because once it starts - watch out you are in high pressure mode. And finally, just because you have water dripping from below has nothing to do with the pump - you probably just have a small leak at the hose connection. One other thing - these pumps are supposedly go bad due to overheating after maybe 30 hours of use. Mine did. Just flat out busted after a two hour wash. Tried a replacement engine but busted that trying to install. Back to Home Depot for me.
