Question about Toshiba Satellite Pro L300 Notebook
HOW CAN I TEST THE RAM IN MY TOSHIBA SATELLITE M40X IF IT IS FAILING
    Sergeant:
  • 223 Answers
There is a program called memtest x86, if you run simple search for the program memtest you will find it for download. This has to be run at boot time, so most versions are designed to be made as boot disks such as "hirens boot cd". this is what i would run at my shop to test the memory, let it run for a good couple of errors to see if any errors show because of a heat issue. cheers
Posted on Aug 30, 2010
How do I unlock my scroll lock on my toshiba m40x
Reboot to access Bios, Select F7 to reset all to default. There is a separate option in Bios to unlock scroll lock.
Oct 16, 2012 | Toshiba Satellite M40X-114 M40X-118...
Can i install mcafee anti virus on my toshiba m40x that is 6 years old
I don't recommend this antivirus, even a good free a/v is better. Try avast, you can download it from download.com it is very good and I recommend to my customers as free option. Now, if you can afford $40 at year your best choice is norton antivirus. Before you install any antivirus you MUST uninstall any previously antivirus from your machine from control panel.
Mar 18, 2011 | Toshiba Satellite M40X-249 M40X-258...
Toshiba Satellite 1005-S157 shuts down periodically by itself. Replaced fan/heatsink. Still shuts off.
you need to check a few things... when the fan/heatsink assembly were replaced, did you make sure that the thermal pads on the CPU and GPU are NEW/Good.... Make sure that the Heatsink GPU pad Firmly sits in the chip....
You can test the thermal controller by using a hair dryer or heat gun.... Point it onto the heatsink pipes and see if your fan spins when the pipes get hot, then remove and see if the fans slow after a minute...
You might have faulty RAM or Misseated RAM... Pull The RAM chips and reseat them...
Also Make Sure Your CPU Is Locked Down....
Periodic Shut Downs Can Be Caused By Quite A Few Different Things...
Typically it's due to Thermal Damage
Though Failing RAM or A Failing Hard Drive, Overheated Video/GPU Chip, Or Even Failing CPU can as Well Cause This Issue...
Nov 16, 2009 | Toshiba Satellite 1005-S157 Notebook
I want to change the CPU fan in my Toshiba Satellite M40X
I found an awesome site
I found the service manual for the Toshiba Satellite M40X in PDF format
You want chapter 4 replacing the cooling module.
http://tim.id.au/laptops/toshiba/satellite%20m40%20tecra%20a4%20dynabook%20vx4.pdf
Nov 10, 2009 | Toshiba Satellite M40-S417TD Notebook
No boot up on my Toshiba Satellite M40X laptop!
try to clean the memory the bronse pin use dry clothes or pencil eraser then put it back, if encounter same error maybe got problem with flex cable come from motherboard go to lcd panel
Aug 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
try booting without the battery installed.
Apr 07, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite Laptop M40X-Z008 RAM STICK INSTALL DIFFICULT
I couldn't find any info on your laptop either. But, I did find contacts for you..
http://www.toshibadirect.com/td/b2c/contactus.to
Jan 01, 2008 | Computers & Internet
Replace toshiba satellite m40x (z008) 60GB toshiba HD with a Samsung HM160JC 160GB HD
both HDs must be either sata or ide and each one must not have a password lock.
good luck
Dec 14, 2007 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite Pro L300 Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
