Question about Vacuums
I HAVE AN IONIC BREEZE QUADRA PROFESTIONAL ONE SERIES SILENT AIR PURIFERTHIN WIRE IN THE BACK BROKE IN THE BACK AND IT DOES NOT WORK NOW. THE CO. FILED FOR BANKRUPTCY AND I NEED TO KNOW WHERE I CAN HAVE IT FIXED. I LIVE IN NEW JERSEY.
2 Suggested Answers
  • 34 Answers
SOURCE: my silent ionic breeze GP
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=0&ProductId=473&gclid=CKWj6N--u6cCFYjsKgodLxrBBQ
Airpurifierrepair will fix your unit but it starts at 159.00 flate fee.
Here are some other things to try first:
Dirty Collection Grid.
  • In case of a problem with your Ionic Breeze air purifier, the first thing you should do is clean the collection grid. According to the Ionic Air Breeze instruction manual, the most common problem with the units is that the collection grid gets too dirty and the unit no longer effectively cleans the air. Removing the collection grid from the top of the unit, then wiping it down with a damp sponge or rag, as well as turning the entire unit upside down several times to dump out any dirt from inside the housing, will help restore the unit to maximum operating efficiency.
Glowing Blue
  • Another common problem with the Ionic Breeze unit is that it no longer glows blue, which it is supposed to do when operating in germicidal protection mode. If the unit is no longer glowing, it is likely that the UV fluorescent bulb inside the unit has died or has decreased in output. The bulbs are meant to last for about a year, and touching the bulbs or getting them in contact with oil or dirt will shorten their lifespan. Try replacing the light bulb before assuming there is a more serious problem with your Ionic Breeze air freshening unit.
Transformer or Circuitry Issues
  • Other problems that may occur with the Ionic Breeze that you will need to troubleshoot and repair include transformer or circuitry problems. If the transformer goes bad, the unit will not work at all, and will have no power when you attempt to turn it on. Similar problems can occur if the circuit board is defective. Because of the danger of electrical shock or damage, it is best if you have a repair facility work on your Ionic Breeze unit if you suspect transformer or circuitry problems
Posted on Mar 07, 2011
How to change belt on hoover breeze 2300
click link below for the manual it will show you on page 7
http://service.hoover.co.uk/manuals/BR2201.pdf
Feb 06, 2016 | Hoover Vacuums
When we changed the belt the new belt broke right away and the brush roller wouldn't spin. My husband cleaned off the roller and got it moving slowly again, but when we went to re-attach everythin
the thing you call wheels are actually called roller bearings that fit at both ends of the brush-roll there probably seized up you can get a new brush-roll with bearings from the link below.
http://dirtdevil.com/parts/category/brushrolls-uprights/
Oct 30, 2012 | Dirt Devil Breeze Bagged Upright
Chord plug broke
go to any hardware or home store even dollar shops --where ever u choose to go buy a replacement/repair plug .this is not a hard repair cut off plug end strip cover back 1 inch and strip back the wires separate the repair plug usually 2 or 3 little screws- slide wire up into sleeve and connect green wire to u shaped connection- white to silver color[sometimes the connections are not colored ] -black to goldish connection put plug togeather and ur done
Dec 18, 2011 | Electrolux Vacuums
My silent ionic breeze GP just stopped working (no blue light, no static). only a couple of years old. cleaned weekly. how do I obtain someone to possibly fix it as trouble finding replacement?
Glowing Blue
Mar 06, 2011 | Vacuums
We owe ionic pro turbo air pur. ever since we cleaned it first time, it's making this static noice and it get really loud at times that it makes hard to sleep. What can we do?
Water or debris in the collection blades or wires can cause a snapping or arcing noise. Water should have dried after a day or so. Look for a hair or lint that is between the blades and wires. Ionic also suggests that the noise may be from misalignment of the blades after cleaning. They suggest removing and replacing the blades to reset the position.
http://www.ionicproturbo.com/images/IP_TurboPro_Manual.pdf
Good luck from Detroit.
Mar 02, 2011 | Vacuums
Replacement bulb for S1720 Ionic Breeze GP
You need a G6T5 bulb.
Here is one of many online sources for this bulb:
http://www.replacementlightbulbs.com/lampg6t5.html
Good luck.
Rain bow E series power head
Maybe these pictures will help, I think your wire broke off by the hose.
Feb 02, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Remove suction motor on rainbow vacuum
Take off the water tank, remove the screw, should be four, that will separate the 2 pieces, remove the rubber seal, remove the screws, 8 If I remember, disconnect the wires to the motor, it should pull out. Replace motor, hook up the wires, screw it back together, glue the water seal back on.
Jan 04, 2008 | Vacuums
Vacuums Logo
52 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
