Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi dlp blinking orange light - Mitsubishi WD-52525 52" Rear Projection HDTV
  • 108 Answers
SOURCE: Panasonic Power Light Blinks Orange twice
sounds like the lamp driver or ballast is defective. That was a major issue on these model.
Posted on Jan 11, 2009
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Posted on Nov 29, 2008
SOURCE: Red blinking status light on DLP Mitsubishi TV
how do you get the tv back on when the light keeps flashing
Posted on Sep 10, 2010
ladywinn
  • 5138 Answers
SOURCE: mitsubishi WD65C9 dlp starts to turn for 2 seconds
Lamp and check Lamp Fan Mats has Lamps for $99.00 1-800-628-1118
Posted on Oct 02, 2010
Mitsubishi dlp wd y65 orange light blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 07, 2016 | Mitsubishi WD-Y657 65" DLP Projection TV...
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
Mitsubishi dlp tv wd65837 wont turn on.
Hello Ejaz,
You will also probably need to change the blown fuse for the lamp also located near the lamp. The blinking orange led is just showing that the circuitry cannot sense any light output yet!
Good Luck!
Rich Lilja
Mar 26, 2015 | Mitsubishi Televison & Video
Mitsubishi wd-73c9 status light blinking orange won't turn on
may need the lamp replaced pt# 915B403001
Recommend Phillips, OSRAM or Mitsubishi original (as from experience others will not work or will have very short life)
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73C9
Mar 08, 2015 | Mitsubishi WD-73C9 73" DLP TV
5738 status light blinks red 5 times then orange 7 times
if it is a 7 then u must replace.
SOURCE: i am a mechanic
Jan 21, 2012 | Mitsubishi WD-65738 DLP TV
I have a mitsubishi 735 series dlp tv. Has red blinking status light. The error code was 4 blinks then two blinks. Do you know what is wrong with it?
That's the error indicating the lamp/ ballast fan has stopped working. You can get the Mitsubishi lamp / Ballast fan 299P321010 used in the V39 series DLP televisions. It comes with installation instructions and is available from www.tvrepairworld.com under the Mitsubishi DLP parts category.
Aug 25, 2011 | Mitsubishi Televison & Video
Dose not come on
Your DLP lamp is out.... Order one online and install it yourself. Instructions are in the owner's manual
Jan 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
654 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
