Question about Texas Instruments TI-Nspire Graphic Calculator
After installing my new OS on my TI-Nspire, the only thing i get is an image of Loading Operating System and nothing else. What should i do?
What you should do is go to http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=71970 format your Ti-Nspire and install version 1.7 then after that install v2.1 hope that helps.
Posted on Oct 02, 2010
My Calculator is saying operating system not found. Install OS now. How do I install Os?
To transfer the operating system to the handheld, connect your handheld and computer with a USB Connection Cable and use TI-Nspire™ Teacher Software with TI-SmartView™ or TI?Nspire CX Student Software (Windows® / Mac®).
This is the link that will download the OS (it's free) to your computer:
http://tinyurl.com/nrkpy3e
Aug 12, 2015 | Texas Instruments TI-Nspire CX Graphing...
My TI NSPIRE CX CAS is stuck at the loading screen - it keeps loading and then going back and repeating (only when plugged in). I have tried resetting it whilst holding down EE, doc and enter. When I do...
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and
the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
• While holding these keys press [on].
Please Note: For TI-Nspire Family handheld units that
contain rechargeable batteries you can alternatively hold the above
keys while pressing the [reset] button on the back of the handheld rather than
removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu
with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit
restarts.
• 2: Delete Operating System - The operating system will be deleted
without deleting any documents on the system.
• 3: Delete Document Folder
Contents - This will delete the user's documents, but will not delete the OS.
Selecting this option is the same as using the RESET hole on the back of the
unit.
• 4: Complete Format - This will delete the OS and all documents for a
total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled.
Oct 09, 2013 | Texas Instruments TI-Nspire CX CAS...
Download new OS and now stuck on Loading Operating System Screen
Hello , I'm a french boy and I have a bad English If you want solve this problem you want to keep HOUSE ENTER AND "P" button et you keep ON HOUSE ENTER and "P" button. The Ti nspire load and a new menu open you make the option 2 , and you install OS 1.7 or 2.0 because the problem is a TI problem beacause the boot is not the name . The french forum who you can read the solution is http://tibank.forumactif.com/problemes-divers-f9/sujet-tn-spire-bloque-sur-loding-operying-system-a-la-suite-t6088.htm :)
Sep 20, 2010 | Texas Instruments TI-Nspire Graphic...
I just got a Ti-Nspire graphing calculator. I recently tried updating the OS on it to the V2.1 but it keeps freezing on me when the loading bar reaches full and says "Loading Operating System". What is...
The same thing just happened to me with two TI-Nspire clickpad units after I had successfully installed the new OS on two other units. I have 30 units to go and do not want any more rendered useless. On a previous update I had to send one back to TI for a replacement when it had this problem. I have posted this problem on TI's support website and hope they will respond with a better solution. I will call 1-800-TICARES on Monday and speak to someone in technical support. I suggest you do the same.
Aug 28, 2010 | Computers & Internet
I installed the new 2.1 OS to my TI-nspire and when it restarts it always freezes at the "loading os" screen with the bar completely filled all the way.
First of all you will need to erase your calculator by holding Home(house key)+enter+P and than the on button. Make sure the on button is the last button you press. Then, select option 2 to erase your operating system. Then, you need to obtain the operating system 2.0 for the calculator. Download and install that onto the calculator. It should install operating system 2.0. Once you do that, download and install operating system 2.1. This will allows you to upgrade your calculator to the latest version and get past the full bar loading screen. Let me know if you need anymore help.
Aug 19, 2010 | Texas Instruments TI-Nspire Graphic...
I downloaded the new OS and it reloaded and it never turned back on. it just stays on the loading screen.
First of all erase your operating system. Then, find and install operating system 2.0 first. Once you do that, you can download and install the latest operating system onto your calculator. It should finish the loading screen.
Aug 06, 2010 | Texas Instruments TI-Nspire Graphic...
I just put in new batteries. I just hit the on button... nothing happened. It wasn't woking before so I thought the batteries were dead.
Here is what the TI knowledge base says about a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Jul 24, 2009 | Texas Instruments TI-Nspire Graphic...
My TI-nspire CAS doesn't want to go on! I changed batteries! Tried the contrast buttons! Nothing works
Try the other recipes from the TI knowledge base concerning a calculator failing to turn on
Jun 10, 2009 | Texas Instruments TI-Nspire Graphic...
I have a TI-nspire CAS calculator. When it is switched on it begins loading and then comes up with System Error. What do I do?
You should ( a suggestion) reset the OS by pressing the button on the back of the unit.
If that does not work, you may consider reinstalling the OS. The procedure as described in the TI Knowledge Base is as follows.
What steps are required to reinstall the TI-Nspire family operating system?
To reload the device’s OS using a computer with TI-Nspire Computer Link:
• Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable.
• Open the TI-Nspire Computer Link software. The select device dialog should appear, and detect the device.
• Either drag the OS file (available in the ‘downloads’ area at education.ti.com) onto the TI-Nspire File Browser portion of the window, or click Tools -> Install OS.
To reload the device’s OS using another TI-Nspire or TI-Nspire CAS device:
• Connect the two devices using the USB Mini A to Mini B cable. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
• On the sending unit, access the document chooser by pressing [Home] [7]. Once in the document chooser, press [Menu] and choose 9:Send OS…
NOTE: Users can only send an OS to a unit of the same model. Users cannot send an OS from a TI-Nspire to a TI-Nspire CAS.
Please see the TI-Nspire guidebooks for additional information.
Hope that helps.
May 08, 2009 | Texas Instruments TI-Nspire Graphic...
Here is what the TI knowledge base says about a calculator failing to turn on.
Mar 08, 2009 | Texas Instruments TI-Nspire Graphic...
Texas Instruments TI-Nspire Graphic Calculator Logo
286 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
