Question about Whirlpool Refrigerators
Whirpool refrigerator model GS6SHAXKS01. Ice maker does not fill and indicator light inside freezer is not lit.
  • 2,272 Answers
There is a water valve in the unit which lets the water in the ice maker.If this valve is faulty then the solenoid valve needs to be replaced.But if the solenoid valve does not solves the problem this its blocked water passing line to the ice maker.Check out if the line is frozen or blocked by dust or ice cubes.If all this checked ok and still the same problem,then its the faulty ice maker board and it has to be replaced.As you mentioned that indicator light inside freezer not working so this is also indicating towards faulty control board for ice-maker .But all other possibilities has to be first confirmed ok then only the board has to be checked and replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
Not making ice but water dispensing ok whirpool ed5lhaxwboo thanks for any help
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Ge refrigeration model 20-25 icemaker not making ice
Fill ice maker with tap water and allow the water to freeze. If when the ice maker cycles and drops ice into ice bin it chooses not to refill with water at end of the cycle. That would point to the dual water control valve. If ice maker does nothing when filled with tap water that will indicate a defective ice maker. The model number you listed does not appear to be correct. Look around the fresh food section door frame and see what you have. This could be the ice maker or the dual water control valve causing this problem. Thanks Sea Breeze
Nov 16, 2012 | GE 20.3 cu. ft. Bottom Freezer...
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
My Whirpool Bottom Freezer Refrigerator keeps collecting ice at the bottom of the freezer and eventually, every couple of weeks, leaks onto the floor. It does have an ice maker which is not hooked up. We...
The defrosting heating element may have burnt out. Also if the gasket around the door/drawer isn't sealing correctly moisture from the air leaking in could be condensing inside and then freezing causing the build up.
Please rate my response.
Jan 14, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Maker is not working on Whirpool model GD5NHAXMB00
Hi, Make sure the temp in the freezer is 0 to 5above zero. You might have another problem causing the icemaker to act up.
IfI can help further, please let me know.
Vic
May 11, 2009 | Whirlpool GS5SHAXN Side by Side...
Ice maker not working
first ch3eck to see if there's ice in the fill tube blocking the water. if that is the case then you will have to replace the solinoid valves on the unit.
Apr 03, 2009 | Whirlpool GS5SHAXN Side by Side...
Samsung rs2555sl ice maker trouble
check to make sure that the tube that fills the ice maker is not froozen upo and causoing this problem
Feb 21, 2009 | Samsung RS2556 Side by Side Refrigerator
Ice maker won't stop dripping
If your i/m is dripping you most likely have a crack in the ice mold, you should replace the ice maker.
Jan 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
Whirlpool icemaker not making ice
optics would not gon bad from frozen water, strictly a computer watching ice level in ice bucket. it should however be lit blinking at least, if it set ot on positoin and no indicator light is on at all sounds like a bad emiiter/ reciever.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
