Question about Lenovo 3000 C200 Notebook
Frozen controls cannot access past password stage cursorfrozen will not turn off
    Sergeant:
  • 458 Answers
What brand of laptop is it? If it is a password problem with a laptop BIOS you are possibly SOL. They have ATMEL chips that have to be hacked. That is not easy to do.
Need more info.
Posted on May 08, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    You did not give me enough information to answer this. What did you do to your computer before this problem started? You did not say if it was a Windows password or a BIOS password.
Toshiba laptop will not go psat the toshiba logo
There are a number of stages to go through. For all these please ensure that the laptop is switched off. First, remove the battery, then plug the mains charger lead in and try to boot, if you get past the splash screen than it is the battery at fault, if not then the next step is to switch the laptop off close the lid and turn it over, on the bottom you should see an access door with either one or two screws, open this access panel up and remove the hard drive, turn the laptop back over and try to boot up again, it should go past the splash screen and the detect that there is no hard drive installed, if it dose not get past the splash screen then turn the laptop back over re install the hard drive, try again to boot up, if still no good then try removing one of the memory chips, these are found under the same access panel. Try again if still no go then remove the other memory chip and replace the first one you took out. If no joy after all these steps, then sorry I have no further suggestions. Good luck.
Feb 03, 2014 | Toshiba Tecra R850 Series Black Notebook...
I locked my self out of my dell latitude d620 Administrator password
Crack Dell Laptop Password ' Want To Hack Into Dell Notebook Computer / PC?
  • Usually, We may create a user password to protect our Dell laptop. Unfortunately, we often forget the password then can't access the computer. This article will tell you how to crack Dell laptop password.
May 07, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
Adamo xps is frozen after it boots windows so I can't put my password in. Ctr Alt Delete doesn't work either so it seems that my keyboard is not working. What do I do?
on the pc using safe mode(press F8 when starting) you can access through administrator account and then go to control panel>useraccounts>desired account> remove password and so you can remove the password
Aug 20, 2010 | Dell Adamo XPS Laptop with Intel Core 2...
What is the best access to the 2000 323i blower moter
remove Remove the glove box and rear trim panel to access blower motor, are u sure it is not the blower speed control that is the source of your problem? that is the most common failure
Here is a copy of the instruictions to replace that component if needed courtesy of Just Answer.com
I believe that the component the BMW tech was referring to is the blower final stage (like an electronically controlled blower resistor assembly). This is a very common failure item on this model, and causes the symptoms you describe.
BMW has a revised part number for this component, which lasts much longer than the original design. When you call the BMW dealer for the part, it is #(P/N 64 11 8 385 549).
The IHKA blower final stage resistor is located behind the right side footwell vent duct. Here is the replacement procedure:
(1) Remove the glove box and rear trim panel to access the area behind the duct.
(2) Remove the two attaching screws from the stepper motor bracket and carefully disconnect the flap rod from the stepper motor arm. Remove the stepper motor to access the final stage resistor. Note: Do NOT turn on the ignition switch while the steeper motor is removed from the case.
(3) Remove the connector from the final stage resistor and the two attaching screws. Remove the IHKA blower final stage resistor and replace it with the improved PN 64 11 8 385 549
Nov 22, 2009 | 2000 BMW 3 Series
Aspire 5610 won't go past stage 3 configuration update
If you need to reformat the system, you can usually access Acer's built-in eRecovery by pressing Alt-F10 at the splash screen. Just bear in mind that restoring the system to factory specifications will erase the contents of your hard drive, so please ensure that your important data is backed up before doing so.
The "Vista Boot Loop" is a known issue though, but does have a solution, see here
If you are unable to use the repair portion of those steps, there is another workaround, but requires the use of other bootable media, such as Ubuntu (which you can download for free here). From there, try following these steps to get the pending.xml file renamed (see Comment #12 specifically, when using Ubuntu)
If you can solve it using the latter method, then you can get back into the system without having to reformat the entire hard drive and starting over.
May 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
We can not get past the feeding stage it is the only part of the house we have access to.
you have to feed the baby 3 times before you can move on to the next month then more activities are available
Mar 25, 2009 | Buck My Baby Girl NDS for DS
Removing BIOS Password
If you remove the battery and put it back in than there well be no password. By doing this you are removing the password information from the CMOS. settings.
Here is a link on how to take out the battery on you desktop computer. Just remember to replace it!!!
http://www.ehow.com/how_8159_change-battery-computer.html
Jan 02, 2009 | Dell OptiPlex GX150 PC Desktop
Frozen Sony K850i
you need to have the phone's firmware reflash you can do this online www.topsony.com or take the phone to a mobile service center and and have them fix it for you
Mar 13, 2008 | Sony Ericsson W850i Cellular Phone
Lenovo 3000 C200 Notebook Logo
87 people viewed this question
Top Lenovo Computers & Internet Experts
Brian Sullivan
Brian Sullivan
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
