Question about Cisco Linksys E2000 Advanced WirelessN Broadband Router Network Routers
Trying to connect to xbox live and its saying there is a problem with my router settings and when i try to get to the page its asking me for a user name and password but when i set it up i never created a name and password
  • 4 Answers
Hi- Have you tried admin for the user name and password for the password?
Thanks
Posted on Aug 30, 2010
It says I can't connect to Xbox Live because my router doesn't have sufficent MTU settings. It says I have to go on my PC, goto my router configuration webpage and somehow either assign MTU settings...
the xbox site has a good list of solutions: http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/kb/error-your-network-does-not-have-sufficient-mtu-setting.aspx?kbid=979104
From that list, here's a couple simple things to try:
If it has worked before, try rebooting your home router (or unplug it from the outlet, wait 10-15 seconds, and plug back in).
If it has not worked before, and it is wireless, it may be a weak or wireless signal. Try moving any cordless phones away from the xbox or home router, or moving your router to a different location, even a couple feet away.
Mar 05, 2011 | Microsoft Xbox 360 Console
Wireless adaptor was working fine until xbox live update, and since the update is unable to pick up our wireless netowork. Tried switching everything back on and on and re synching modem with xbox, to no...
To connect your Xbox 360 gaming console to a NETGEAR router's wireless network:
  1. Turn off your Xbox 360 and disconnect anything from the I/O port on the back of the console.
  2. Insert your Xbox 360 wireless adapter to the I/O port as instructed by the wireless adapter manual.
  3. Connect the wireless adapter cable to your Xbox 360 I/O port.
  4. Flip up the network adapter's antenna.
  5. Turn on your Xbox 360.
    • If you are using an unencrypted wireless network, your Xbox should connect to it automatically and you do not need to proceed to Step 6.
    • If you are using an encrypted wireless network click the System tab, and then click Network Settings and continue with Step 6.
  6. On the Network Settings page, select Edit Settings.
  7. On the Edit Settings page, select your wireless settings on the Basic Settings tab.
  8. On the Select Wireless Network page, select your wireless network.
  9. On the WEP Network page, type your wireless network key, and then click Done.
  10. On the Apply Settings page, click Test Xbox Live.
  11. If this is the first time you have connected your Xbox 360 to Xbox Live, you will probably be prompted to apply an update. If there are no updates, the Xbox Live Connection page shows that you're connected to Xbox Live. Press the Y button on your controller to continue.
If testing the Xbox it says DNS failed, then update your NETGEAR router firmware:
  1. From your computer, open an Internet Browser and navigate to http://kb.netgear.com to download the firmware for your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. Click Router Upgrade on the top left pane under Maintenance, browse for the firmware downloaded and click Upload.
  4. Wait for the router to reboot.
Dec 20, 2010 | NetGear MA101 802.11b Wireless Adapter
Restricted nat for xbox / linksys 160n router need to open
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here
to know more about router and network
Apr 20, 2010 | Linksys WRT160N Wireless Router
Cant connect to xbox live. ive used my laptop b efore but now it will not let me can u help me? i think the settings are messed up when i test connection from xbox to network it doesnt go any further
First access your router then check its settings of ip address.
It must be in the range of your router settings.
Means if your router ip is 192.168.1.1 and subnet mask is 255.255.255.0
Then your xbox ip is 192.168.1.3
gateway is 192.168.1.1
It is good enable DHCP in your router so your xbox get autoip from router if you set suto ip getting from router.
For that For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then Enable DHCP in router then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 31, 2010 | Microsoft Wireless Network Adapter Xbox...
Have the n+ wireless router/modem trying to connect via a cable to xbox live but keep gettin insufficient MTU even though the actual MTU of the router is higher than required
You may have to use trial and error to find the best MTU fit:
MTU Default of 1500 to 1492
Tart the setting the MTU @ 1400
MTU setting. Xbox LIVE requires a minimum MTU setting of 1364.
The information your console sends and receives is broken up into "packets" for transmission over your network. MTU is a setting that controls the size of these packets. If it's too small, you won't be able to connect to Xbox LIVE.
Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
Solution 1: Check your router MTU settings Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Solution 2: Connect directly to the modem If your router's MTU is set correctly, try bypassing it by connecting your console directly to the modem. This will help determine whether there's a problem with your router or something else on your network.
Note
This may require you to move your console to a location close to your modem. This is a temporary arrangement, meant only to troubleshoot your connection. If your console is connected wirelessly, you'll need an Ethernet cable for this step.
To connect your console directly to your modem (wired connection):
  1. Find the Ethernet cable that runs between your console and the router.
  2. Unplug the cable from the router, leaving it connected to the console.
  3. Find the Ethernet cable that runs between the router and the modem.
  4. Unplug the cable from the modem, and plug the cable from your console in its place.
To connect your console directly to your modem (wireless connection):
  1. Unplug the USB connector for your adapter from the console. The adapter can remain attached to the console.
  2. Plug an Ethernet cable into the Ethernet port on the back of the console.
  3. Find the Ethernet cable that runs between your router and the modem.
Try to connect to Xbox LIVE again. If it works, there may be an issue with your router. Double-check the MTU setting in solution 1 above. Also confirm that you're using a compatible router, and make sure it has the latest updates from the manufacturer. If the problem persists, you may want to try a different router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 06, 2009 | Belkin N1 Vision Router
360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
Xbox live
Hello!
Yes, the netopia router will work with xbox live. you just have to configure some settings on your router.
To configure your router for Xbox Live try the following steps below:
step 1: Open an Internet Explorer page. in address bar type your router ip address, That should take you to the Netopia's settings page
Step 2: On the menu to left click Firewall, set it to Low and Save Changes
Step 3: On the menu to left click Expert Mode, then Yes, enter Expert Mode
Step 4: On the menu to left click Configure, then Advanced, then NAT
Step 5: Where it says Service Name, scroll the list down to Xbox Live Games, click Enable and then Enable again
Step 6: On the menu to left click Configure, then Connection.
Step 7: In main page scroll down to the UPnP and put a check in the box. then Save
It should then restart the Netopia, and when it comes back on in a few seconds your XBOX LIVE should be good to go. If you are still experiencing problems accessing Xbox Live your Netopia may require a firmware upgrade.
May 10, 2008 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Media access crontrol (MAC) address
Hi Stevetabor9,
Finding and Registering Your Xbox Console's MAC Address
  1. Turn on your Xbox console with no game disc in the disc tray.
  2. From the Xbox Dashboard, choose Settings, and then Network Settings.
  3. The 12-digit number at the bottom-right corner of theNetwork Settings screen is the MAC address of your Xbox console. Do not change your Xbox console MAC address; just write it down so that you can use it later.
  4. If you have a direct connection from your Xbox to your modem, you'll have to disconnect it and reconnect your PC to access the Internet.
  5. From your PC, open the following page:
    British Columbia: http://oca.bc.hsia.telus.net
    Alberta: http://oca.ab.hsia.telus.net.
  6. Log in using your Telus Velocity Internet Service account.
  7. Select Manual Registration and Administration of PC's and Devices.
  8. In an available slot, enter the MAC address of your Xbox console, then select Update.
  9. Follow the steps in Direct Connection with Telus to try to connect to Xbox Live again.
Registering Your Router MAC Address
  1. See your router documentation to find your router MAC address.
  2. Before disconnecting your PC from the Internet to set up a router connection, open the following page:
  3. Log in using your Telus Velocity Internet Service account.
  4. Select Manual Registration and Administration of PC's and Devices.
  5. In an available slot, enter the MAC address of your router, then select Update.
  6. Set up a router connection to Telus and try to connect to Xbox Live again.
take care
Mar 15, 2008 | 2wire 2700HG-B Router (2700HGB)
XBOX LIVE
u may need to adjust your modem/router settings check this link out
http://www.jlsnet.co.uk/index.php?page=cc_xbox
Feb 15, 2008 | Microsoft Xbox 360 Console
XBox 360 not compatible with Motorola WR850G
Motorola WR850G router may fail to connect to xbox live after update to firmware 6.1.4. I was able to correct the problem. My solution was
Go in xbox >> network config >> IP and use Static option. Set the xbox to an IP in the range allowed by your router configuration. The router IP config range is found in the router config web >> Lan section. Then I set my router config >> Routing >> DMZ IP Address setting to the xbox ip I just assigned to my xbox. Restart router using the restart button on the Basic page of router config. Restart your xbox and attempt to login to xbox live. This solved my problem.
As a side note, on the xbox networking test page, the xbox live status message will allows show they are aware of a problem with xbox live login. This is a lie. For that reason I postponed trying to fix my router problem thinking it was an xbox issue, it is not. Once you finally connect to xbox live you will still notice this incorrect message remains. Microsoft developers ****...
Dec 26, 2007 | Arris WR850GP Router
Cisco Linksys E2000 Advanced WirelessN Broadband Router Network Routers Logo
167 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
