Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
Brush works intermittedly - I've looked at the common solutions listed but none seem to work...shaking it & reseating the canister will get it working again sometimes but obviously that doesn't seem to be a very good solution. Can you help?
I just had the same problem. I would turn on the vac, and it worked fine. When I turned on the brush it would work for a few seconds then shut off. Through troubleshooting I found out it had nothing to do with a bad power connection. By chance I took off the side HEPA filter to see how it looked. I realized that I have never changed it and that it was filthy. I removed it and turned on the vac, then the brush. It took a few tried, but the brush motor got back to full strength. I reassembled everything and it works fine now. It seems that the clogged filter was causing the brush motor to shut off. I'm running my vac w/o the HEPA filter while i wait for a new one to ship. Hope its the same prob for you!
Posted on Sep 23, 2010
Canister vacuum
Without the make or model... We are speaking in GROSS GENERALITIES... but
ELECTRICAL Trouble...
The light & the BRUSH not working ... when considered TOGETHER.. would indicate a NEED to check your electrical connections...
My best advise would be to:
make sure the cords & wands are fully connected
make sure the (HEAD) motor is running ...
If the motor (brush head) is running... belt looks good and brush is not seized (or jammed)...
You will need to look to the DRIVE PULLEY on the motor OUT-PUT shaft...
Hope this helps
Jul 25, 2016 | Vacuums
I received my dyson a few months ago. I have used it regularly and it performed very well. I used the brush bar on all the carpeted surfaces and turned it off when cleaning the linoleum floor. Just...
Hi Joanne, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC39 Multi Floor. If the brush bar only seems to be working intermittently, we should be able to help - and if a replacement part is needed we can confirm if this is covered under our 5-year warranty.
When you have your machine easily to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to hearing from you.
Oct 13, 2013 | Dyson DC39 Multi floor canister vacuum...
Bissel 3760-4 brush motor doesn't turn on
Hi Tim. I understand the brush is turning & belt is fine. You may want to remove and reseat the canister. If this doesn't work, you'll want to have one of our Authorized Service Centers inspect your vacuum.
Here's a link to assist you in locating one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Apr 19, 2013 | Bissell Lift-Off(R) Revolution(R) Turbo...
My Power head on my Dyson Animal DC39 will not stay spinning. Suction Issue?
There should be a red insert on the right-hand side on the cylindrical bulge behind the brush cylinder. Check that this is moving when you push the button. The red insert should stay pushed in for the brush to rotate. The insert moves in an out as well as rotates in order to lock in the 'in' position. Mine is a little sticky on the rotation and I need to shake the brush head a little in order to get it to rotate and lock.
Jan 05, 2013 | Dyson DC39 Animal Canister Vacuum
Dyson DC22 brush wont spin, does not appear to be getting power
I'm sorry to hear you're having difficulties with your DC22. If you've been unable to get the Motorhead working after cleaning it, please get in touch with us directly so we can provide further assistance. You can call us free on 1-866-693-9766 (US), or 1800 239 766 (AU) - if you're based outside these countries, please let me know where you're located so I can provide the correct contact details.
We'll look forward to helping you resolve this issue.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 04, 2012 | Dyson DC22 Motorhead Canister Vacuum...
The cannister begins to shake during usage
Either you have too much water in it, or your water separator is missing teeth. The water separator is the thing that spins in the center of the motor where your water basin attaches to it. It looks like a cone shaped fan looking thing. It should be cleaned after every use.
Use a your Rainbow separator cleaning brush, or a tooth brush, if you do not have the Rainbow one. They are just like tooth brushes.
You can get manuals either here,
http://www.rainbowsystem.com/ or here,
http://www.rainvac.com
Never store your Rainbow canister on your water basin.
You fill the water basin to the top of the knub thing that is inside of it.
If it is a standard water basin, it holds two quarts, of water. If it is the larger one, it holds 4 quarts of water.
If your vacuum begins shaking or swaying during usage, that meens that you need to poor out the dirty water, and start over with fresh water, because the water level will rise as it gets dirtiet.
If you have any more questions, let me know.
I am a Rainbow vacuum expert.
Thank you,
Ralph
May 26, 2010 | Rainbow 75th Anniversary Canister Vacuum
DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Mar 01, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Electrical to power head
Greetings from GoVacuum,
There could be a couple of reasons why you are not getting power to your power brush. The first and most popular reason is the hose of the machine. Sometimes the wires inside of the hose will go bad, causing the power not to get down to the power brush, but the rest of the vacuum working well.
You can test this hose easily. You will need to go out and purchase a continuity tester from Home Depot or Radio Shack. When the electrical test is in the continuity position, remove the hose from the canister, and put one of the testers on one of the electrical prongs that plugs into the canister itself, and put the other tester into socket where hose connects into the wand, you should have continuity on both terminals. It is important that the switch that controls the power brush is turned to the on position. If one of the terminals does not have continuity, you will need to replace the hose itself.
If both terminals have continuity, then you should then follow the same procedures on the electrical wand. If the wand tests ok as well, you may have a loose connection in the power brush.
Please let me know if none of these solutions work for you, I can then shoot a video showing you how to open the power brush to check for loose connections.
You do have a Miele S548, correct?
Please feel free to email me with any questions, I really enjoy sharing my knowledge of fixing and repairing vacuums, and would be delighted to answer any questions you might have.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Aug 09, 2008 | Miele S548 Bagged Canister Vacuum
Bissell Vacuum 5770 intermitent spinning brushes
Change the belt, they stretch after a short time and then it can't drive the brush roll under load. The part # is 2031329
Jun 03, 2008 | Vacuums
Canister works, vacuum doesnt
There could be a break in the electric from the machine to the hose - or from the hose to the wand - or from the wand to the Power Nozzle - or it could be the motor is bad.
Wiggle the cord at the Hose with it running- then go to the Wand - then to the Power Nozzle. You may find a break in the wires anywhere along the line.
unplug the Vacuum:
If you have a meter check to see if the reset is working - and last check to see if the motor will work removed from the Nozzle.
Ralph
ifix@shentel.net
Oct 17, 2007 | Filter Queen Majestic Canister Vacuum
Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
654 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
