Question about HP Officejet Pro K5400 All-In-One InkJet Printer
My HP office jet pro k5400 series has blobs of ink all over the document, how can i stop this from happening.
    Problem Solver:
  • 11 Answers
Have you tried replacing the ink catridge? If so, are you using new ink catridges or refurbished/refilled?
Posted on Aug 30, 2010
  • denisepontre Aug 30, 2010
    Yes, I just replaced the cyan cartridge and that is the color that is blob'ed on my printout. The other colors are off as well.
How do I replace the yellow ink cartridge?
Open up the Panel It has the writing HP office jet pro Etc. on it, then the cartridge/head will move toward you, push in on the yellow cartridge until it clicks and release it will disengage and you can remove old cartridge.
Installation is exactly like removal insert new cartridge until it clicks release and it will engage.
Close panel and the cartridge/head will move back to previous position
Jun 02, 2015 | HP Officejet Pro 8600
Is the green light on my Office jet k5400 suppose to be blinking?
the green light on your printer can be blinking, here are the causes:
  • The printer is either turning on or off.
  • The printer is processing a print job.
  • The printer is paused while the ink dries.
Just try to wait for a while, and it should be all right again.
Lucas
Jul 11, 2011 | HP Officejet Pro K5400 All-In-One InkJet...
OfficeJet Pro K5400...ink cartridge
Er, NO.
The answer to the above question is clearly misleading.
If you consult the documentation for your HP K5400, which can also be found online, you will find that the printer cartridge lights also blink when the print heads require replacing.
If you have replaced the cartridge and the light still flashes, this is the most common solution. Replace the print heads.
Unfortunately because the printer is badly designed, there is no way of indicating this, and you will have troubles if you attempt to get the HP Toolbox or any other diagnostic tools working.
Feb 12, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
Printer HP Office jet Pro K5400 Paper jam happened now we cant print anything. Orange button with ky just keeps flashing. Can you help please?
This typically means there is still paper stuck somewhere in that. My guess is that whatever paper as removed tore as it was pulled out. Look carefully everwhere you can.
Friendly, Inexpensive, REMOT Computer help!
Nov 23, 2009 | HP Officejet Pro K5400dtn Printer
On HP K5400 printer the Left margin for #10
See an online manual with instructions to change the print settings here., then open the document program that has the addresses in it and use the print preview and page setup to adjust the margins for the printing to 1/4', if they'll go down that low.
Jul 10, 2009 | HP Officejet Pro K5400dtn Printer
HP 2500C Pro Series Color Ink Jet with Error Code 432
The problem is with the service station. This is the unit that the carrier "Parks itself" over when it is not printing. It cleans the print heads and collects excess ink. It also fills up with ink. and the ink dries in a big blob.
If the motor is good, if it was working it likely is, The SS probrably got jammed in the move.
Try this:
If you can move the carrier to the left with power off do so.
If not turn machine on and while carrier is to the left unplug the machine.
You need the carrier to the left to expose the SS.
Open the cover as if you were changing printheads.
Look straight down. your looking at the service station.
A shaft with wipers and a gear at one end should turn. A little resistance but jam if alot of ink is caked in the bottom of the unit.
You can clean some of this in from the top and see if the SS frees up as a test at least.
The service station can be removed if required. You need to remove the right cover from the machine.
There are three screws that you should see looking down at the SS from the top They have numbers next to them I beleive, holding the SS in. Everything that moves should move freely.
Hope this Helps Good Luck
Feb 27, 2009 | HP DeskJet 2500C Pro InkJet Printer
HP Officejet Pro K5400 All-In-One InkJet Printer Logo
103 people viewed this question
Seeker5211
Seeker5211
