Panasonic Viera TH-42PV60A dead screen and sound
While my TV was on with a video camera connected to it via the front AV input the screen and sound died but the video camera continued playing as normal. I turned the TV off and back on and the red power supply light came on and there was a clicking sound as if the picture was initiated but then nothing happened.
I left it off for a few days and tried again but the same thing happened, this television is just under two years old, what do you think the problem could be??
  • 1,512 Answers
Hi Ninny
Strange problem to occur. Sounds to me like the TV has developed a fault. I think that it just may be a coincidence that you happened to have a camcorder plugged into it at the same time. I would be calling Panasnic and express your concern about its untimely failure... Products with a reputation like Panasonic should last longer than 2 years. If you express your concerns firmly, manufacturers often will help you to sort out the problem. If not under warranty, then at least contributing parts to the repair. Ring a Panasonic Authorised service center in your area. I am not sure where you are in the world, but if you need me to find someone, then let me know where you are and I can get on the case. :)
regards
robotek
Posted on May 08, 2008
I'm trying to plug my ps-3 to my panasonic viera th-50pz80u with an AV multi-out but i have no signal. No sounds, no images. Please help me
In your PS3 configuration you'll likely have to set the PS3 so that it is using the multi-AV rather than HDMI.(In Video Output Settings) Also on the TV input you'll have to select composite in rather than HDMI.
https://support.us.playstation.com/app/answers/detail/a_id/788
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Hope this helps,
Jeff
Nov 03, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
TH-50PX77U inputs
Many times a computer's post screens will not show up a TV set, and once the computer itself has loaded the drivers and settings, the set may need to be shut off and turned back on for the HDNI or PC signal to be detected.
It is also possible the settings you selected for display properties cannot be displayed on the TV.
As far as the component video signal, are the connections correct? Sometimes people mistake the composite red, white and yellow for the composite system that divides the red, blue and green video signals.
While also possible, but rare- there may be poorly soldered connections on the "A&D" board (logic board) .
Jul 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic Viera TH-50PX80A. After lighting strike, inputs do not work.
The set MAY have a hard reset but you would have to call Panasonic to find out.
What happens with lightening strikes is RF gets into the set in two ways--via the power cord (usually a dead set is the result) and via the coax or cable fitting.
It sounds like it was the latter--it may have confused the microprocessor in the set(input issues) so unplugging set and or a box if used (receiver unit also!) may or may not help.
Surge protectors rarely operate quickly enough to stop this and even if the cable feed is protected stray RF can get past that also.
try my suggestions and then call Panasonic.
May 17, 2012 | Televison & Video
I cannot turn off closed caption on screen. Panasonic Viera Plasma TH 42PV60A
hi,
To exit closed caption do the following.
1. Press the menu button and select CC and press OK button.
2. In CC menu select MODE and using right arrow or left arrow button select it OFF
3. Press OK button
4. Press menu button to exit menu option.
ok
Mar 10, 2011 | Panasonic Viera TH-42PX80U Plasma TV
I cannot record from a Daewoo DVD recorder ( 8150P) through my Viera TV ( model TX-L32S20B ). The screen says No Signal and instructs me to check inputs. I've tried using all cominations of AV1 and AV2...
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
Mar 08, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
We have connected our asus K52J lap top to our panasonic viera plasma TH-P50V20A via a HDMI cable . We have picture ON THE TV but sound from our lap top only. How do we get sound from our TV
Hi there
I've just looked at that TV model, and it appears that your TV does not support a separate audio connection for HDMI sockets. It also appears that your laptop model has a issue with sending audio via HDMI. Are you running Linux, or windows?
Hope this helps
TV_Doctor
Jan 03, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Viera TH-46PZ85U. gray box where picture should be
If it was a setting on the television, then the cable info would also be affected. Try a reset on your cable box, as the cable info is generated within the box from the data stream, whereas the picture is streamed from the provider.
If the reset doesn't work, it's time to call the cable company - it's not a fault with your telly.
Mar 05, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic viera doesn't display computer correctly
Right click onyour desktop and click properties (Windows XP) or personalize (Windows Vista).
Click the tab that says Settings(XP) or the link that says Display Settings (Vista)
Adjust your resolution by sliding the bar up or down until your dispaly matched the optimum resolution of your TV.
Dec 29, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Televison & Video Logo
189 people viewed this question
Top Televison & Video Experts
