Question about Freezers
Stopped cooling -fisher and paykel fridge
4 yrs old firdge
suddenly stopped cooling
nil cooling now.
still hear the sound from the compressor.
please tell me what to do
    Scholar:
  • 149 Answers
Ok you say the compressor sounds right?? there's probably a defective relay overload / start cap combination defective. if you go behind the the fridge and remove a small cover you will see the compressor with power disconnected look for frayed or burnt wires take the compressor cover off and you will see the wires just follow the 3 wires. you can buy a replacement relay/overload capacitor combination all you have to do is wire it any additional questions you can e-mail me at hvac.tech7872pr@gmail.com
have a nice day
Posted on May 09, 2008
Fisher and paykel xrss 267BB fidge freezer
The system is either blocked or you have a gas leak but i would expect it is blocked and the only way to find out is to get a refrigeration engineer to check it for you, but explain the problem to him first and make sure he can help before you spend money.
Jul 19, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge water sound
This kind of noises produced gas in cooling system.
In the old coolers never heard sounds like streaming water because the compressors were very loud due to high pressures (12 bars or more), which were required for efficient cooling. Today we use more ecological gases which work (from 5 to 6 bars) at much lower pressures, thus compressors produce much less noises and now suddenly we hear sounds that never before heard. Generally speaking noises is lower, measured in decibels.
Dado
Feb 01, 2014 | AEG Freezers
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
GDM-33SL-60 not cooling
Is the compressor (the football-sized case on the outside back of the refrigerator) making a continuous hum or other noise? A constant noise could indicate a serious problem with one or more components. This is a repair that should be left to a refrigerator service expert.
If you hear a clicking noise every few minutes, this means your condenser is trying to work but can't. If your condenser coils are clean, the problem could be the start relay, which triggers the compressor. Have a refrigerator repair pro determine if the start relay is the culprit and to replace it if necessary.
For more help identifying the causes and solutions, read Refrigerator not cooling. I hope this helps!
utube.png You-Tube video "sfMv4SgMjDs" placeholder
Oct 08, 2012 | Freezers
Frigidaire refrigerator compressor overheated when I left the door opne.
the motor of the compressor may have tripped on overload protection. Allow it to cool down and then unplug the fridge then plug it back in and try to run it. It should run. Be advised that the condenser coils underneath need to be clean. You should have a strong person tilt the empty fridge while you vacuum and clean all the dust and lint off the coils. Be gentle as these coils are fragile and are easily damaged. Hope this helps.
Mar 26, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
Fridge 14 yrs old. Unplugged for 2 yrs - now won't cool.
with the unit being that old , the compressor probably whent out the oils inside probably froze up ,,,,, to replace a compressor you are better off replacing the unit it is a major repair
Jan 31, 2010 | Fisher Freezers
Fridge is not cold but the light will turn on...
if its a fridge freezer fully defrost it 48hrs
Feb 07, 2008 | Freezers
BEKO TZS490
AS A FRIDGE ENGINEER I HAVE COME ACROSS THIS PROBLEM BEFORE IT COULD BE A LOSS OF REFRIGERANT ALTHOUGH THIS WOULD STEADILY WORSEN IN USE,MORE LIKELY THERE IS A BLOCKAGE IN THE SYSTEM STOPPING THE REFRIGERANT REACHING ALL THE PIPEWORK THE CHEAPER FREEZERS USE THE SHELFS AS PART OF THE FREEZING SYSTEM.
THE ONLY SOLUTION IS A COMPRESSOR CHANGE AND REGAS (COSTLY IF NOT COVERED BY WARRANTY/GUARANTEE ETC)
IF FREEZER IS MORE THAN 5 YRS OLD BEST TO SCRAP IT UNFORTUNATELY..
Dec 19, 2007 | Freezers
Kenmore chest freezer not working
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Sep 25, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore freezer not cold at all!
We had a Kenmore upright which worked fine but then suddenly was not keeping food frozen. Long story short, do not store anything on top of the freezer unit. It will insulate the coils that run across the top of the unit, and cause your compressor to work harder than it needs to, and eventually overheat and become ineffective. Says nothing about it in the user manual. We learned the hard way by losing food.
Jul 30, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
112 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
