Question about Intel Easy PC Camera Webcam
I have a intel installation cd but its not working on my mac
Can I sync Palm OS 4.1 from one PALM IIIC to another Palm IIIC with 3.5.2 installed
The only suggestion I have is to download the trial version of VMWare Fusion and installing Mac OS 10.6 or earlier as OSX 10.7 and higher has Rosetta removed. Rosetta allows your Intel Mac to emulate PPC and run PPC programs
Jun 05, 2016 | Computers & Internet
Need to Install Mac OS on Intel based PC
MAC OS X can work in Intel computers but it might need to be cracked to install, In my opinion try dual booting your computer this mean making another partition on your hard drive to install MAC OS X to for the time being to see if it will work on your system and hardware
Feb 09, 2012 | Apple Computers & Internet
Just got an lg ge20 not working on mac
I wish I could tell you that your Mac is compatible with the LG GE20 20X DVD Burner but unfortunately it is not.
Here are the system requirements for this burner
LG GE20 20X DVD Burner Technical Specifications
The CD included is not the only item that is not compatible with the Mac, it is also the DVD burner itself. It is only windows compatible I'm afraid.
However, I do know that the Apple.com online store, has a comparable DVD+RW burner, the
LaCie 22x d2 DVD+RW with LightScribe
which will work with your iMac.
This is a genuine incompatibility issue.
If you had an Intel iMac, there actually is a workaround process where virtual machine software, like VMWare Fusion or Parallels, could be installed, with a version of Windows XP, Vista, or 7, display as a 2nd terminal within a Mac OS X desktop.
What's makes this effective, is that the LG GE20 could work with a windows virtual machine and because software like VMWare for example, can share devices, including optical CD/DVD drives, the Mac could share that drive with the windows virtual machine.
But since you do not have an Intel iMac, unless I am reading the description of your Mac computer(Apple iMAC Mac Notebook) incorrectly, the LaCie burner information, I provided above, would be the best option for your model of iMac.
Again, if I have described your model of Mac incorrectly let me know and I will be glad to assist further.
Regards,
-Mactechtrainer
Feb 01, 2010 | Apple iMac Notebook
ZooTycoon 2 wont install into my mac
Hi Bee
I'm guessing here. Eject the CD. Open your hard drive and locate the Zoo Tycoon folder. Open it and try running from there.
Jul 29, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Mac OSX 10.4.11 Error when installing the Epson NX400
If you're running the install program from the install disk CD, it may be attempting to create a work folder on the CD instead of your hard drive. I would drag a copy of the install program onto your hard drive first and then launch the copy on your hard drive.
Let me know if that solves your install woes...
best of luck on this.
K
Jul 24, 2009 | Epson Stylus NX400 InkJet Printer
Using on an Intel MAC machine???
It doesn't appear as though that scanner is supported under Mac OS X... No drivers are available anywhere, and it's not a popular enough brand for any to be included in the OS. Sorry! I had an older Canon scanner that wasn't recognized by anything in OSX, so I feel your pain!
Please rate this answer if you feel it has helped you!
May 11, 2009 | Office Equipment & Supplies
My mac just wont start up. The little wheel that
maybe u not installed the system MAC Os properly or maybe your cd while installation has corrupted during installation.During this process u should not corrupting the installation.Or maybe ur computer MAC Os has a virus.I recommend u use kaspersky internet security for more protection...
Feb 23, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Folder with blinking question mark in it after start-up
Folder with a blinking question mark means a missing system folder, in other words there isn't an OS installed. To fix this you need to boot from the OS X installer CD. With the OS X installer CD in the drive, hold down the C key on your keyboard when you start your mac. This tells the mac to boot from the optical drive (i.e. CD drive) and load the OS X installer. From there just follow the onscreen instructions to install OS X.
Also, you should be aware that the ibook is not compatible with Windows XP. Only the newer “intel macs” of the past few years are compatible with XP. Your mac predates Apple's transition to intel processors and Windows XP compatibility on the mac platform by a few years. This is why your Windows XP CD didn't load on it. The ibook is Mac OS X only.
It only runs on Mac OS X however it is compatible with newer versions of the OS. 10.2 jaguar is kind of old and a little buggy. You may want to consider installing 10.4 Tiger for improved stability and performance. Avoid the newest version (10.5 Leopard) as it is geared towards newer and faster machines.
Hope this helps. Enjoy your mac
Feb 03, 2009 | Apple Computers & Internet
Windows
Hi benny, im Nick from germany.
In order to install Windows on a Mac computer you'll need these things:
- Apple Macintosh with Intel Processor
- Windows XP Install CD with Service Pack 2 or higher
- You can also use Windows Vista CD
To get started, you just need to start the mac and do a search for "Bootcamp" in Spotlight (the search in MacOSX, top right corner).
Note: This only works on Mac OSX Leopard, for Tiger its a little more tricky.
Once you started Bootcamp, it will guide you through the process of partitioning your harddrive and installing windows.
If it doesnt work, its probably the fault of the windows install cd. I had to use 3 different versions to get it to work.
If you need additional help, feel free to ask =)
Jan 21, 2009 | Computers & Internet
Intel Easy PC Camera Webcam Logo
13 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
