Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Voltage meter reading is in the negative when pto is engaged
  • 472 Answers
Sounds like the cluch could be bad ck your battery make sure its good i
Posted on Aug 30, 2010
Blades suddenly stopped engaging, tractor runs, drives
It is most likely the the electro magnetic clutch failed.
It can be read out with an ohm meter for continuity, only 2 wires. Also verify when disconnected that it is receiving voltage from the Pto when the Pto switch is energized.
Jun 14, 2016 | Garden
John Deere Z840A Z-Trak mower. Why does engine die when PTO is engaged?
A possible cause is an open seat switch (operator presence). Locate the switch under the seat & unplug the switch from the harness. Place a small jumper wire into the female socket leads to the wire harness. If the PTO engages without engine shutting down, replace the seat switch.
Check to see if the mower deck is plugged or a piece of wood/debris is wedged between the deck and a blade, or some wire/rope is wrapped around a spindle. If the blades don't turn by hand, it'll stall your engine when the electric PTO clutch is energized.
Lastly, a discharged battery will cause an engine shut down if there's not enough reserve when the PTO is engaged. Measure the battery voltage with a meter. If the voltage is below 11.5 volts, you may have to replace the battery.
Oct 23, 2015 | John Deere Garden
Why doesn't clutch engage when PTO turned on?
your electric clutch is stuck ,broke
Sep 25, 2015 | Cub Cadet Garden
Toro 11-32 won't start.new battery. i jump the terminals it fires right up. 2nd problem is the deck won't engage I hit the switch and nothing I leave the seat it shuts off when engaged
Check and see if the Engagement termnal on the solenoid is getting power. If it is replace the solenoid.
As for the PTO check for at its connector for voltage. If voltage is there check for about 1.7 ohms resistance across pto coil. If it reads infinity or less than 1.5 ohms replace the pto clutch assembly.
If the pto reads less than 1.5 and there is no voltage at the connector than the pto switch is probably burned up due the shorted pto.
May 14, 2015 | Toro Garden
When engage pto notice that voltage on battery drain is that cause bad pto
Can be if its coil is partially shorted. These usually 5-7 amps current-wise.
Disconnect the pto clutch wire connector at the pto clutch assembly. Using multimeter do a ohms test on the engagement coil. If it reads less than 1.5 ohms then it is partially shorted.
I have seen clutches to work even pulling up to 15 amps when partially shorted which more than most small engine alternators can produce.
Mar 30, 2015 | Garden
M9960 kubota tractor pto wont engage. Dash reads error code 11 please help and what does error code 11 mean
This could be a low voltage problem. Check the voltage output with a volt ohm meter at the stator output.
Nov 12, 2014 | Garden
Why will my zd21 kubota zero turn mower pto clutch not engage
First check fuse. Then with a volt meter check for voltage on the 2 wires going to the PTO clutch with the key and pto switches on but motor off ( you may need to trigger the seat switch as well). IF voltage is detected the clutch its self is suspect. If no voltage then check for power into the PTO switch and then out of. If power in but not out then the PTO switch is suspect. And keep chasing voltage down the line until you find the failure. Voltage travels from key switch thru fuse, PTO, seat, and reverse switches to the clutch
Sep 01, 2014 | Garden
I have a ariens zoom 1540 mower it runs fine but the blades wont engage to mow. It worked when i put away after last mowing and 2 days later it doesnt. Ive checked the wires off pto switch and they seem...
You've checked the wiring to the PTO and it looks OK. Does the PTO engage when the switch is thrown? Do you have a multi meter , so you can trace the voltage to the switch, from the switch to the PTO. You also should check the safety switch (s) which will prevent the PTO from engaging if there is a faulty switch. And it could simply be a fuse that has blown.
Jun 20, 2014 | Garden
On John Deere lawn tractor when we pull the yellow button up to engage the blades to start spinning, they dont move.
If you have an electric pto switch, the switch, connecting wire from the switch to the pto clutch, or the clutch itself could be defective. You can check the switch and wire with an ohm meter. You can also check for proper voltage at the pto clutch plug.
Sep 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine runs-- PTO will not engage after control switch is pulled
first check the connection at the clutch cub are know for this. also check the fuse block for a blown fuse. then still if nothing check to see if your getting voltage at the clutch. to do this unplug clutch and with a volt meter test for dc voltage. it should read 12-14 volts. if not try changeing the pto switch.
Mar 03, 2010 | Garden
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
