Question about GE GDS20KBS Bottom Freezer Refrigerator
THE REFRIGERATOR ISN'T COOLING, BUT THE FREEZER IS STILL WORKING FOR UP TO 3 DAY AFTER TOP STOPS COOLING, THEN THE FREEZER WILL GO OUT AND DEFROST EVERYTHING WHAT IS CAUSING THIS PROBLEM
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 30, 2010
This is for a kenmore top mount Refrigerator/Freezer Model Number 25363712302. Refrigerator was not cooling properly - was warm. Freezer was working, but after a couple of days, freezer also started to...
Since you say that is isn't cooling properly, I would first start off by cleaning the condenser grill that is located under the cabinet. While this won't correct your problem entirely, it will help!
Most likely you have a defrost system malfuntion. The defrost system consists of the defrost heater (p/n: 5303918208) which is the long tube like thing that sits directly below your evaporator behind the panel in the back of the freezer (inside the freezer). It also consists of the defrost thermostat (p/n: 5303918202), which is located next to the evaporator. Both the defrost heater and defrost thermostat can be checked with an ohm meter - a non-open/infinity reading is good. If both of those check out and are good then it has to be the defrost timer (p/n: 215846602) which is located behind the plastic shield (with the light bulb).
Suggest you defrost the unit (making sure no ice or frost is behind the freezer panel then plug the refrigerator back in. If everything cools down then my diagnosis is correct and one of the components of the defrost system is bad.
Oct 03, 2011 | Kenmore Top Freezer Refrigerator
Freezer isn't working and refrigerator isn/t cooling. What is the problem? We can hear the fan running however.
my refridgerator is a Maytag side by side did the same thing checked the freezer compartment fan was working removed cover to look at the cooling coil, the coils were frozen solid ended up defrosting freezer compartment every other day. replaced the adaptive control board located in the refrigerator side top, haven't had another problem since.
Nov 15, 2009 | Maytag MSD2756GES Side by Side...
No air circulating the no frost refrigerator. Electrolux 2 door
It sounds like a defrost problem. Maybe the defrost timer is not advancing or it could be the heater in the freezer. Find the defrost timer and advance it to defrost. You will hear a click and the compressor should turn off. Then wait about a minute, unplug the cord slow. You should see a spark when you unplug. If you do then the heater is working. Change the defrost timer. If no spark then it could be the heater or terminator.
May 14, 2009 | Electrolux ER7526 / 1B Top Freezer...
Freezer and Refrigerator section stopped working
check your drain line and check defrost system, defrost thermostat, heater, and timer
Nov 30, 2007 | Maytag PTB2154G Top Freezer Refrigerator
Refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
GE GDS20KBS Bottom Freezer Refrigerator Logo
98 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
