Question about Amana ASD2627KE 26 Cu. Ft. Side-By-Side Refrigerator w/ Electronic FrontFill Dispenser & Adjustable ...
The water dispenser in freezer door does not completely shut off water... it will drip and fill a drinking cup in about an hour... the water filters has been changed reciently.... can I fix this myself?... thank you in advance....
    President:
  • 1,218 Answers
Good day,
If it fills normally, then continues to dribble, it is a defective dual water valve located on the bottom rear of the machine. What is happening, is the diaphram in the internal part of the valve will no longer completely seat.
No repair is possible to the valve, it must be replaced with a new one, but is a fairly easy job.
The valve is a popular item and should be available at any decent sized appliance parts house.
After shutting off the house water supply, grab a hand full of towels, since there will be some back flow when disconnecting the inlet and 2 outlet lines.
Posted on Aug 30, 2010
How do I "Prime the Water Supply System" refereed to in use and care guide that came with my new Kenmore French Door Bottom Freezer, #253.70413411. Cannot find instructions in the manual only reference to...
Assuming you followed the water line installation directions and you have water available to your new refrigerator/freezer here is the rest of the "priming" info you requested. (basically it tells you how to run a bunch of water through the system by filling cups or glasses to remove any debris and/or air...
Automatic Ice & Water Dispenser
Priming the Water Supply System
1. Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle. 2. Keep the glass in this position until water comes out of the dispenser. It may take about 1½ minutes. 3. Continue dispensing water for about three minutes to flush the system and plumbing connections of any impurities (stopping to empty the glass as necessary).
Ice Maker Operation & Care After the refrigerator is installed properly and has cooled for several hours, the ice maker can produce ice within 24 hours. The ice maker will fill the ice bin from the rear. You must dispense some ice to force the ice forward in the bin. This will allow the bin to fill completely.
Turning the Fresh Food Ice Maker On and Off Ice production is controlled by the ice maker's On/Off icon on the control panel. Press and hold the "Ice Off" icon for three seconds to turn the ice maker "ON" or "OFF". The ice maker is turned off when the LED above the "Ice Off" icon is illuminated.
Using the Ice Maker after Installation Before making ice for the first time, be sure to prime the water supply system. Air in new plumbing lines can result in two or three empty ice maker cycles. Furthermore, if the system is not flushed, the first ice cubes may be discolored or have an odd flavor.
CAUTION
For proper dispenser operation, recommended water supply pressure should fall between 30 psi and 100 psi. Excessive pressure may cause water filter to malfunction.
NOTE The water dispenser has a built-in device that shuts off the water flow after three minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle.
IMPORTANT On occasion, unusually small ice cubes may be noticed in the bucket or in dispensed ice. This could occur in normal operation of the ice maker. If you start seeing these more frequently, it may be an indication of low water pressure or the water filter needs to be replaced. As the water filter nears the end of its useful life and becomes clogged with particles, less water is delivered to the ice maker during each cycle. Remember, if it's been six months or longer since you last changed your water filter, replace the water filter with a new one. Poor quality household water may require the filter to be changed more frequently.
IMPORTANT Your ice maker is turned on at the factory so it can work as soon as you install your refrigerator. If you cannot connect a water supply, set the ice maker's On/Off icon to Off and turn off the water supply valve; otherwise, the ice maker's fill valve may make a loud chattering noise when it attempts to operate without water.
Hope this helps. Randy
Mar 02, 2015 | Kenmore Refrigerators
Fridgidaire refrigerater dispenses water
The part number you are going to need is 241734302. This is the water valve located in the back of the machine. Whats going on is the solenoid for the dispenser isn't seating properly and when the icemaker calls for water the pressure is enough to push through and come out the door as well
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 24, 2012 | Refrigerators
The freezer door leaks water from the water/ice dispenser. The dispenser fills up with water. Items in the freezer door almost seem as if they never freeze. All items in the door are much less frozen...
Leaky dispenser-------
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Sep 09, 2011 | KitchenAid KSCS25FKSS Side by Side...
Ice maker makes ice but freezes before it can be dispensed so the dispenser is always clogged with frozen ice. Cleaned out the ice maker and started over but same results. The temp is set at 38 for the...
Hi, The freezer should be "0", the possible clogging you have could be a leaking water valve or an over filling ice maker. I would have the ice maker checked for volume of water dispenser during harvest, should be 5.5 oz. (2/3 cup), if more the 6 oz. the ice maker is bad. If fails to stop filling or leaks/drips, replace the water valve behind the unit.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 27, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
WATER DRIPPING FROM DISPENSER IN DOOR. GE Model TFX20JRBG WH
You are correct. this is actually a faulty inlet valve(dual) assembly. replacing this faulty valve will fix this issue.
Jun 19, 2009 | GE GSH25JFR Side by Side Refrigerator
Water keeps dripping after it dispenses water thru the door
When you push the button, the CLICK you hear when the water flows is the Water delivery solenoid opening to let water thru, then snapping shut when U R done. The Spring is weak (prob wrong type, size, strength at factory) or the valve seal is cracked, torn, hardened or crushed.
Since all this is inside the door, you will either have to take it apart to see/fix/replace.
Quick fix: turn down the water pressure coming in(?)
Call Mr. Handyman to fix.
If under warranty - they might fix this for you for free
If this is a factory defect, there might be a recall in place for repair/replacement parts
Googlee both - Make/Model + Dripping Valve + Recall
Good Luck!
Jan 17, 2009 | Frigidaire FRS3R5EMB Side by Side...
NO DRINKING WATER
common problem the water line inside the freezer door is frolzen up . to fix remove everthing from the freezer door , turn off freezer . open freezer door and put a blanket over the opening to the freezer leaveing the door to room temp for an hour or so to defrost . check if defrosted . remove blanket close door . this will happen with ge , try seyying the freezer control on the next lower number (warmer)
Jan 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Water dripping from the water dispenser on freezer
If the water is dripping from the dispenser tube, you need a water valve. The valve is not shutting off completely. Check to make sure water is not dripping from ice chute. If the chute door doesn't seal off you will get moisture there and it will also frost up the ice chute.
Sep 30, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Amana ASD2627KE 26 Cu. Ft. Side-By-Side Refrigerator w/ Electronic FrontFill Dispenser & Adjustable ... Logo
52 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
