Water spilled on laptop
My toddler nephew spilled a huge glass of water directly on my laptop while it was plugged in and on. The screen fizzled with lines and then went black. I took the battery out and left the computer out to dry for several days. I tried plugging it in again to see if it was ok and the screen is black. What can be done to fix it, if it can be fixed at all/
  • 2 more comments
  • mshar May 21, 2008
    Some lights do come on but i know it's pretty much a lost cause :( thanks though.
  • vishal  verma
    vishal verma Nov 20, 2008
    HP Pavilion dv6500 notebook i have the same problem if any one can gv any
    solution
  • Anonymous Nov 28, 2008
    i have the same problem with an IBM, nothing on the screen and it doesn't turn on at all. took out all the parts and i figured out that the problem is from the power supply but the power supply is integrated into the motherboard. basically, the motherboard is trashed.
  • Eric Smith
    Eric Smith May 11, 2010
    Do any lights come on at all?
    Sergeant:
  • 458 Answers
No way to repair this problem.
Posted on May 08, 2008
Hi, I spilled a large quantity of water on my HP dv7t laptop last night. It was a huge glass, and because of this the laptop just automatically shut off and i didn't even have time to turn it off. I...
I am assuming your motherboard is fried, but your Hard Drive is still OK. The laptop may not work anymore, but your files are more than likely recoverable.
Apr 17, 2011 | HP Pavilion DV7T 17" Laptop
Coffee got spilled on my laptop keyboard. The laptop seems to work fine all except for the keyboard. When I push the keys, something different shows on the screen other than the letter I pushed. Like if I...
How to Fix Spilt Liquid on bda25ce.jpg?
You accidentally knocked fruit drink or a late night glass of milk on your laptop or your child spilled a good portion of milk directly into your keyboard. You hear a popping noise, the screen goes black. Water by itself is not as bad as milk or juice, both of which are corrosive/acidic, or coffee, tea, soda, etc.
First and most important -Calm Down and unplug the computer from its power source.
Disconnect it from the power cord and remove the battery. If needs, please remove the keyboard. The old adage - Water and Electricity don't mix - is quite true. For your laptop spilled water, let your laptop dry. Do not attempt to turn on the computer for at least 72 hours. Let it sit in a cool, dry place. If you disassembled the laptop, reassemble it after 72 hours have passed.
Oct 13, 2010 | Computers & Internet
I have a Toshiba Satellite® M105-S3041 and my toddler spilled juice on the keyboard and now it won't turn on. When I plug it in, the battery charges, and the blue power light comes on, but the screen...
Most likely you are going to need a motherboard, depending on the model, under the keyboard is the palm rest assembly...most of these have many opening in them that will allow fluid to get directly to the motherboard and they do not do well with liquid spilled on them when they are energized. Below is the link to the service guide for that model. I usually get my mobos on Ebay, but there are other sellers to grab one from.
http://tim.id.au/laptops/toshiba/satellite%20m100.zip
Jul 04, 2010 | Toshiba Satellite M105-S3041Notebook
Water damage
The only solution is send it back to service center. Maybe to many part malfunction
Not worth it to repair it,.
May 13, 2010 | Dell Latitude D600 Notebook
Hi cannot find wirless button on samsung laptop
First, plug your laptop into the wall. This allows for the laptop to be powered off the wall current. Next you need to get a large glass. Fill this glass with water and blue food dye. While the laptop is plugged into the wall, turn it on. Then you need to pour the glass of water on the laptop screen while closing it slowly. Leave the laptop alone for about five minutes after this, and then open the screen slowly. The screen should now display your configuration of where things like USB ports and the wireless button and settings are.
Enjoy!
Mar 17, 2010 | Samsung Laptop Keyboard for X20 X25 X30...
I spilled a glass on wine on keyboard. now get blank screen yet, all the power lights and sound is still on.
You May Have Shorted Out The Video Card Which Is Usually Located under the keyboard you can get a replacement through Tiger Direct...
Apr 03, 2009 | HP Pavilion dv6000z Notebook
I have a Brother intellifax 2800. It's leaving streaks on all my fax output. How do it fix this problem.
On the Intellifax, there is a glass bar that runs across and allows the fax machine to read the image. Take out the entire drum unit and you should see that bar in the middle of the machine, careful it can be hot. Take an alcohol swab, or a q-tip dipped in alcohol and rub it from left to right on the glass bar. You may also see some spilled toner that is causing the streaks. Remove any toner with the alcohol swabs, do not use water or try to vacuum (huge mess if you do). You do not have to get all the toner, just make sure the glass bar is clean. That should do it.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Water spilled on laptop....LCD screen appears fainted...?????
Don't worry, water won't damage your screen permanently and will 'evaporate' in time, but for now you have to live with the effects it has on your screen. It will be more like a few months then days but it will heal in time
Hope This Helps
Nov 21, 2008 | HP Pavilion dv6000z Notebook
it has gone to the big computer grave yard in the sky i'm affraid, the best thing you could do is strip it down and sell the parts
sorry
Nov 20, 2008 | HP Pavilion dv6000z Notebook
Water stain inside of screen glass
Yes, you can check with ctechnicians.com for instructions on disassembling.
Dec 23, 2007 | Hitachi 60EX01B 60" Rear Projection...
Computers & Internet Logo
251 people viewed this question
David Payne
David Payne
