Question about Whirlpool WGD5800S Dryer
Its generally takes about 100 mins. to ddry a load of clothes. How cn I adjust the thermostat on the dryer?
    President:
  • 3,074 Answers
I would check my vent hose as it must be clogged or crimp somewhere. Hope this helps tim
Posted on Aug 30, 2010
It takes 50 min to dry a load of clothes in my 400 series electric dryer can you tell me the problem. I checked the exhaust it looks clear thanks.
It could be heating problem and best way is to check for continuity in heating element and sensors and thermostats and limiters and thermistors in the dryer
Nov 17, 2010 | Kenmore 400 6943 Dryer
Delic ate cycle taking too long to dry
This is normal because the delicate cycle is a low heat cycle.
Aug 01, 2009 | Dryers
WHIRLPOOL LER6620PTO DRYER TAKES MORE THAT 40 MIN. TO DRY A LOAD OF CLOTHES. WAY TOO LONG
Hi, you are correct. this drying time is quite long. i recommend checking the following areas on your unit to combat this issue. the most common issue here will be a clogged vent hose or blower housing obstruction.
Check the following---
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 17, 2009 | Whirlpool LER4634J Electric Dryer
My dryer heats up, but the clothes dont get dry w/o 3 full cycles
Remove the exhaust vent from the rear of the dryer. Run a timed load at 45 minutes. If it dries correctly clean your connecting vent your wall vent and the lint from inside the machine.
May 27, 2009 | Dryers
Slow to dry cloths
Remove the vent from the back of the dryer and see what the temps are. The cycling (or operating) thermostat is on the blower housing and opens more than 100* lower than the 266 you are reading. That, combined with the long dry times indicates an airflow issue. Check your lint screen....fabric sheet and lint can combine to coat and restrict air flow through it. Also check down in the blower housing with the lint screen removed. You'll see lint build up by looking down the slot with a flashlight. If it's restricted, so is the blower wheel and the blower housing. Also make sure the flap, or lovers at the vent hood outside are opening fully. Remove any accumilation of lint from there.
The high limit control is just that........If you cycling thermostat has failed, or does not open because there is no airflow, the limit control opens as a safety. On a normally operating dryer, the high limit control will never open.
The neptune dryer is designed to move more air than a regular dryer due to the higher capacity load it get's from the neptune washer. That is the case with most front load laundry pairs.
May 06, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer taking longer to dry clothes
For a gas dryer:
Assuming the dryer is working properly and the control cycles are ok, look for things like a restricted venting system which inclides the exhaust, lint screen, etc. This would be the large pipe connected to the dryer exhaust that vents outside.
If it's an electric dryer, there could be issues with heating elements, thermostats, a control board, the timer, etc. Also check for any excessive lint build-up.
Apr 12, 2009 | Dryers
Dryer
your dyer stat has gone you can see this when you take the lid off make sure you unplug the machine its normaly the white one it has two wires the other one is black that's the clod one leave that only take out the white one and go down to your appliance shop and ask them for one take down the model of your machine first onece replaced job done
Jan 07, 2008 | Hotpoint Aquarius WD63 Front Load...
My hotpoint vtd00 dryer seems to have stopped drying
Have you cleaned the exhaust ducting? The duct that runs from inside to outside. Try that first. Sounds like your exhaust line is blocked. Also with the filter out get a flash light and look down the venting if alot of lint vaccum out. NOTE: Unplug the unit, wheather gas or electric.....and if it is a gas shut off the gas to the dryer before moving just in case something gets loose while moving. Hope this helps.
Nov 11, 2007 | Hotpoint NWXR473EV Dryer
Whirlpool WGD5800S Dryer Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
