Question about Kenwood KDC-MP208 Car CD/ MP3 Player
What wiring harnesses are compatible for this stereo?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
Should use a standard kenwood harness. you can get one from pacparts.com
Posted on Aug 30, 2010
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
How to connect pioneer fh-x700bt to a 2004 ford explorer
You need to buy a wiring harness compatible with your vehicle. The wiring harness will connect to your vehicle OEM plug and the other end you need to splice it with the wire that came along with your car stereo.
Apr 16, 2014 | Pioneer FH-X700BT
I bought an after market in dash stereo for my 2005 Pontiac sunfire. I have now tried 3 different wire harnesses that were for my year and none of them fit. I called my local electronics store and was told...
Hello Megan,
It sounds like there is a specific wiring harness required for your Sun Fire.
First place I would start is with the compatibility of the after market stereo. Did the stereo manufacturer provide an application list with the stereo.... that provides the makes and models of vehicles it will work in?
If your stereo purchase is new, can you exchange it for a unit that is compatible with your car, including the necessary and correct wiring harness?
If not....then you will need to purchase the harness that has been identified as correct for your vehicle.
Sep 03, 2017 | 2005 Pontiac Sunfire
My jvc stereo will not power up but have found the black wire is live ?
hi peter, before you start using the rest of the harness cables find out if the harness you have is a jvc original for your model. the black wire is the ground/chassis cable only for a jvc kd-r411. you mite be using a compatible fitting harness whose " wire colour configuration" is incorrect for your model. cheers.
Mar 02, 2013 | JVC AM FM CD DET FACE CAR STEREO
I am looking for a Boss BV9970 wiring harness.
You don't need a wiring harness for the radio unless you lost the one that came in the box with the radio.
You can find a wiring harness for your car here.
Fit My Car
That will list all the things that are compatible with your car, including aftermarket wiring harness to connect a stereo.
Feb 08, 2012 | Jensen VM9510 Car DVD Player
I cant get sound out of my speakers. i put in a new stereo and hooked it up
Did you use a wire harness specific to your vehicle year and model? Make sure you get the right harness, depending on what factory system came with the car(base or mach460 sound systems), If your speakers were working prior to replacing the radio, then there's a possibility that the harness may not be compatible. also, the car may be equipped with a factory amp(mach460 systems). Here's a link that may help you figure it out. http://www.modifiedlife.com/2000-ford-mustang-car-stereo-wiring-instructions/
Sep 23, 2011 | 2000 Ford Mustang
Installing a ptid-8960 power acoustik into my new 2011 mazda 3 what wires should connect or can i even install it without getting the wire harness adapter to make it like the same connections not quite...
You absolutely should use a wire harness for this installation. Not using one would require you to clip the wires to factory radio connector, making re-installation of the factory stereo nearly impossible. Even worse, you would have to wire the connector that came with your PTID-8960 deck to the clipped ends. This task would be nearly impossible, as the factory wiring is too short to extend out of the dashboard where you can work with it easily.
Save yourself the trouble.
I tried finding the exact item you will need, but it seems the Mazda 3 comes with stereo options that could affect which wire harness you'd require.
Here is a link to Crutchfield: http://www.crutchfield.com/p_120707904/Mazda-Receiver-Wire-Harness.html?tp=2977&tab=other_items
You can use their site to select your car and installed options, and they will return products compatible with your vehicle.
Jun 14, 2011 | Car Audio & Video
How to bypass pioneer avh-p5700dvd
The recent pioneer DVD devices structures setup is achievable by inspecting the vehicles default wiring kits to determine the most compatible medium. The prior wires in the vehicle stereo appear mutated with attempt to extract and replace with new DVD stereo. Inspect the mutilated wires to determine the kit harness that allows connecting the new device on one end while binding to the electrical cables extended surfaces. The new stereo player makes possible connection of a multipurpose harness that solves the problems that may be thought to require bypass. Once the appropriate connection kit harnesses are acquire, the wiring should provide connectivity to speakers, tweeters, woofers and several devices as amplifiers also necessary predicted during installation else missing audio may be detected after. Refer to auto installations experts to acquire the complementary parts to attain the installations.
Feb 05, 2011 | Pioneer AVH-P5700DVD Car DVD Player
My car stereo powers up when the key is not in
There's an different wire connection in there that is causing the problem. Even though you didn't need an new wiring harness doesn't mean that everything is compatible. Check the wiring for the power from the radio and the car.
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
Oct 23, 2009 | Panasonic SB-WA100 Subwoofer
Kenwood KDC-MP208 Car CD/ MP3 Player Logo
76 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
