Question about Brother MFC 240C All-In-One InkJet Printer
It won't print black ink. i went and good a new cartridge today to make sure it wasn't that. but it just wont print black ink for whatever reason. please help
  • bigo463 Aug 30, 2010
    whenever i plug in the cord and hold menu it goes to standby...
  • 4,924 Answers
I think you have to go to maintenance mode to operate this fix..
for that follow this procedure..
shut it down ..and remove the power cord...
plug the power chord while holding menu to get in maintenance and press 76. 4. black start.
if it is just a setting issue this will get it back ..but if it is something wrong with the print head you will have to get it to the doctor...
Posted on Aug 30, 2010
  • Catalin Turcu
    Catalin Turcu Aug 30, 2010
    try to do that with the front door open ..and see if it goes into the maintenance menu ..if it do not want to ...try to keep pressed the setting button too ..if it has one ..or ..try this dial ..
    3 times... > black
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
Black ink will not print but colors do
Most likely culprit is a dried up ink within the nozzles themselves. The best things for getting rid of dried ink in the nozzles is to use either a standard bathroom cleaner or rubbing alcohol. With the printer on open the door as if you were replacing ink. With the ink cartidges visable, unplug the printer so they stay put. Remove the cartridge and spray the cleaner in the where the ink is taking from the cartridge and clean it with whatever works. I really really good trick is if you have an old cartridge you can use a syringe to fill up the empty cartridge with your cleaning solution or rubbing alcohol. Insert the cartridge and run some test prints. This will for sure run the cleaner through the nozzle and hopefully dissolve the blockage.
Nov 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
Canon Pixma ip3000 will not print in color. We recently replaced all three color cartidges and when I went to do a nozzle check, it only printed the black part of the test page. Several times. I went...
I find this an unusual problem but lets look at the logic.
It worked ok before your replaced the colour cartridges.
Your replaced only the colours and now it does not.
Did you replace the cartridges with like for like?
Are they compatables? Did you run the cleaning cycle?
Run the cleaning cycle at least 3 times.
If still no good buy 3 genuine canon cartridges and see what happens.
If still no joy then must assume the printhead is the problem.
A bit of a coincidence?
Aug 11, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Lexmark intrepret S405 wont authenticate ink cartridge
I have the same problem with my Impact S305 - stupidly downloaded firmware today and now can't print wont print. I am furious and will never by Lexmark again. It is like buying a kodak camera and finding out it won't work with fuji film. Absurd.
Up yours Lexmark
May 23, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My yellow ink ran out and I finally replaced all inks this evening. Now, with all new inks, I keep getting a message that the yellow needs to be replaced. Any suggestions? I've turned off the printer,...
I had the same problem with mine but I bought a refill cartridge instead of a new one and went through three refilled cartridges when I found that it was that I needed a brand new one. For some reason, the HP printers and some other printers need to know that you are using the same brand of ink as the printer. if it is another brand it wont except it and it wont let you print anything! So make sure it is a brand new hp brand ;)
Nov 12, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Black ink wont print
Clean the head off where the black is with rubbing alcohol and a qtip. If it won't detect the black cartridge and you went into the printer settings and enabled the black to print as well as the color, then the printer sensor that senses new cartridges and amount of ink level is defective and, unless it is under warranty, it's not worth fixing.
Sep 01, 2009 | Epson Stylus CX4400 All-In-One InkJet...
We repalced the black ink cartridge but it wont print black
Most ink jet cartridges have "multiple" protectors to keep the ink from leaking or drying out and the electrical connectors from getting damaged before they are installed into the printer. You should be removing a plastic cap device for the ink, and typically, a piece of clear tape that protects some copper traces on the back of the cartridge. Make sure both are removed. If it still does not work take it back to who you bought it from and have them check to make sure there is ink in your new cartridge. Typically, you can shake it and hear a liquid sound. Good luck.
Toby White-Beebe
Dell Certified Lead Systems Expert
Jul 08, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Ink cartridge replacement
I had the same problem, and after scouring around online for a few days, I learned that this is one of the biggest gripes about this printer. Basically, you're out of luck unless you replace EVERYTHING, even though you only want to print black (nuts, isn't it?). So I went out and bought all new color cartridges, and it STILL won't print. I think it's just a bad printer all around. :(
Sep 07, 2008 | Epson CX8400 All-In-One InkJet Printer
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Brother MFC 240C All-In-One InkJet Printer Logo
22 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
