Question about Cameras
Well. The VX1000 wont turn on at all. I even put the switch on Standby like it should. And the batterys wont charge. Like the batterys go in. And it ONLY flash's green as though its full or whatnot. And it once was red for like an hour. And I put the battery in the camera. And just wouldnt turn on AT all... Help anyone?
  • 374 Answers
SOURCE: Battery Charging Problem
First of all I would make sure that the battery is in correctly. There should be an arrow on the battery that should line up with a plus sign on the battery door. Once the battery is installed correctly then place the camera on the charger and the light should be a solid red. If that still doesn't work then I would be more inclined to think that you may have a defective charger. I would call Casio repairs and see what they can do to help you.
Posted on Jul 17, 2007
SOURCE: Casio Exilim EX-Z70
that happened to me too - you need a new battery.
Posted on Aug 25, 2007
SOURCE: Battery will not charge
Yep. Same hear. Casio will replace with reciept - call 1300 728 606. Pitty I've lost mine!
Posted on Jan 02, 2008
SOURCE: NV3 Camera - won't turn on or charge
Had the same problem and the following steps seemed to fix it:
Removed battery.
Connected charger lead (but using laptop, not charger - not sure if it matters).
Cleaned battery terminals.
Placed battery back inside the camera.
Posted on Aug 04, 2008
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch the positive (+)end of the 9v battery to the positive (+) end of the camera battery.Leave them touching for a few seconds (10 seconds should be more thansufficient). Seems these lithium-ion batteries are subject to a'digital memory.' Subjecting it to a volt surge almost three timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
Posted on Oct 01, 2008
Battery emptied.When i switched on my nokia 5130 express music,it hanged.it does not continue to its standby mode.
try to let it charge overnight (fully charged) and try again.
when its hungry sometimes it wont go into standby.
Jun 27, 2011 | Cell Phones
Hey i just got my sony vx1000 and its not turning on. i put a battery in the camer and it turned on and mediately turned off and now the battery isnt coming out it or turn on. please help i dont know what...
Judging by the cameras response the battery may be low on charge. Try removing the battery (there usually is a button close to where the battery is inserted) and charging it overnight. If it still does not work the battery pack may be dead or worn out. You may need to get a new one as batteries gradually loose their capacity overtime and eventually die.
If the battery is a Ni-Cd or Ni-MH you can attempt to revive it by charging it fully, then discharging it by running the camera, and repeat this cycle many times.
Thanks for using FixYa,
Chartreuse
Jan 14, 2011 | Sony Handycam DCR-VX1000 Mini DV Digital...
The notebook will not turn on. it charges but wont start. it used to start up and stay on for about 5-10 mins before going on standby, but now it wont even start up. What can i do to fix this?
Without the AC power supply connected (e.g. no external power supply), remove the battery pack to force a hard reset on the software controlled on/off switch and wait a few minutes before reconnecting the battery (and external power supply if your battery is flat): try to switch the unit on again.
Good luck and let me know how you go!
Dec 12, 2010 | Acer Aspire One PC Notebook
Only getting about 10 hours standby on Blackberry 8520
Hi one reason batterys dont last as long as they should is that when you charge them up they never achieve full charge and some cells will only take between 50 and 65 % charge, what you should now try is letting the battery go totally flat so that your phone wont even light up when you try switching it on keep doing this until the battery is totally dead, then give it a full recharge, you should now find it lasts a lot longer, you should aim to do this once a month to ensure you battery stays at its best, they dont tell you this when you buy the phone but it is common knowledge in the phone industry.
give it a try and you should be surprised what you find.
How ever you cant always believe what the phone adverts tell you because their are heavy duty batteries you can buy for certain phones, but if you think you have a good case of false advertisement then contact the phones makers and have a word with them they may even send you some free extras as they like to keep their customers happy,
You also got to remember that standby time means 17 days if the phone is not used and no one rings it say you take the sim card out then give it full charge, then with the sim card out see how long the battery lasts then this will give you some idea of the things that use the battery up such as alarms, people ringing, texts, even when you press a button this uses power to light the screen up so you can only rely on standby time if the phone is sitting their doing nothing.
i hope this as been some help to you
May 05, 2010 | RIM BlackBerry Curve 8520 Smartphone
MY COBY MP3 WONT TURN ON EVEN AFTER CHARGING AND
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Mar 27, 2010 | Audio Players & Recorders
My GPS won't turn on or won't charge
Have you tried replacing the battery.
Wont charge? Sometimes if the battery is totally depleted even the charge light will not go on until the battery reaches a certain level of fill. Are you sure it isnt charging? A new battery will confirm its viability to be able to deliver service in future.
Jul 31, 2009 | Sony NV-U44 GPS Receiver
My lg shine wont turn back on...
my sony ericsson is loosing all the programs and suddenly the standby monitor become all white? does it need to upgrade? or reprogram or is there any parts tobe changed? dave of davao
May 30, 2009 | LG KE770 Shine Cellular Phone
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Cameras Logo
87 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
