Question about Yamaha LPX500 Multimedia Projector
Projector is stuck in black and white. NO color. How do I get the color projection back?I checked the cable box source and it is fine
Green screen on VGA with Viewsonic PJD5122
VGA is separated analog signals in Red, Blue, and Green. Under normal cases, you'd be able to change the cable, source, or input port and resolve the issue. Unfortunately, if the green tint persists with all input ports on the projector (The two blue ones are Input, the black one is output. There is a potential that attaching input to the black output port could have caused the damage), different sources, and different cables, then it's likely a problem with the projector hardware itself and would require warranty service or otherwise repair or replacement of the projector. If you have an alternate way the projector can be attached, then try that (Such as SVideo), otherwise there may not be any good solution in this case short of checking the guts of the system.
Mar 28, 2014 | ViewSonic Office Equipment & Supplies
No color,,checked all settings , all I have is black and white
Try viewing a source such as your cable box or computer on your TV. With this source playing, open the TV menu option. If the TV menu is also in black and white then there are a few components inside a plasma TV that can be causing your problem. If the menu appears in color but the video source your watching is in black and white the problem is probably with the source, such as your cable box or computer, rather than your TV. If the video and menu are in pure grayscale and the image is still clear the problem is likely the main board.
Dec 28, 2013 | V, Inc. Vizio P50HD Plasma Television
PDG-DSU30 black and white video
check your HDMI/VGA cable this is sometimes cause the color lost. change it or try another cable...
Dec 05, 2013 | Sanyo PDGDSU30 Video Projector
Projector only projects black and white images
if the cables are fine, try resetting the settings to factory default. if still no good, you may need to replace the colorwheel. you could buy the part and do it yourself, or send it in to an infocus service center. either way, try www.avsolutionsny.com. they're really good.
Dec 10, 2009 | InFocus ScreenPlay 4805 Multimedia...
My projector only shows black and white images
probably you are facing with an NTSC signal and a PAL source or vica versa
try to check with a regular tv or with a different source
Jan 03, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Projects in black and white
It's probably the color-wheel problem. Maybe the color-wheel stucked because of dust and/or color-wheel sensor is covered with dust.
The simple way to check this, without reinstalling drivers or so, you just tap menu button on remote. If you will see only black-white user interface it is definitly color-wheel.
Good luck.
Nov 04, 2008 | Optoma H30 Multimedia Projector
Tinted image
If you are plugging in a monitor cable, it is most likely a cable issue. I would try another cable and make sure the cable is seated firmly into the projector. If that doesn't help, check the port on the projector for bent or missing pins because it seems that not all of the video information is reaching the unit.
Feb 02, 2007 | Sanyo PLC-XT16 Multimedia Projector
Hitachi pj-tx100 black and white picture when using s-video
s-video carries luminance and chromanance. In simple terms, luma provides a a black and white picture, chroma the color data. without chroma, you get no color. Either - the cable is bad (usually in the form of bent/broken pins in the connector ends - the source device is bad - the projector input is bad
Sep 21, 2006 | Hitachi PJTX100 Multimedia Projector
Yamaha LPX500 Multimedia Projector Logo
Top Yamaha Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
mitch_3020
mitch_3020
Are you a Yamaha Office Equipment and Supply Expert? Answer questions, earn points and help others
