Question about Rheem Water Heater Pressure Relief Valve
The water pipes that carry the water throughout the house makes a loud humming noise every three seconds
    President:
  • 1,515 Answers
Hi, it says you are having problems with the relief valve, I am not sure what it is, but they will blow water if the water temperature exceeds its rating and water pressure. Also, says you have a humming every 3 seconds or so in the pipes? This sounds like a classic case of hard water deposits have formed up around the control valve probe that's inserted into the water. Also if the pipes are galvanized and not copper, they will rust up the walls of the pipes over time with deposits also closing of the amount of room for the water to get through. It would really help to know the age of your home and if the water heater is gas or electric? When this happens, you will hear a popping noise at the water heater and you will get air in the pipes that will cause all sorts of noise, humming, growling, the pipes will rattle and with the restricted lines and build up of sediment, the pressure relief valve will let loose to relieve the pressure. If you are having any signs of low and uneven pressures and hot and cold problems, depending on the age of this water heater, you will need to replace it.If it is a gas heater, you will have a round plastic drain knob located at the bottom of the heater. You can turn it ccw all the way open and let the water coming into it from the fill valve on top flush out as much of the sediment as you can. When you have done this, close the valve off to fill it up again and repeat the draining or flushing process. This will also remove any air trapped in the lines. Important! When you are filling the heater if you had shut the fill valve off on top, open the water valve and on the relief valve, pull the lever up to lock it open as this lets all air from the lines out of the heater and the water pipes. If this relief valve is blowing a lot, replace it. Just turn the water valve off on top and use a pipe wrench to turn it ccw to remove it. Look for sediment on the rod to see how much has build up on it. This valve is around $25 and will be cheaper to replace then the heater. The size is 3/4". Temperature range for it to open will be stamped on the old valve. This you can get at any hardware store such as Home Depot, Lowe's, Ace and so on. Pick up a small tub of pipe dope to coat the treads when installing and once it is in, turn water on and raise the lever up as you turn water back on to fill the tank to remove the air. This should solve this problem. Please keep me posted on this and your progress and if you will tell me the age of your home and if its a gas or electric heater this will be helpful if the instructions I have given you do not solve this problem. I do believe it is just trapped air and a faulty pressure relief valve at this point. Please don't forget to rate me as I know you will be kind and please keep me posted as I will check on you as I store your information in my files to look in on at any time I may need.
Sincerely,
Shastalaker7
Posted on Aug 30, 2010
I have a Navien NR 240A tankless which has been in use for about a year. My only complaint is that when the internal recirculation pump turns on I can hear a waterflow or pump noise throughout the house...
Hi Bruce
No its not normal it shud b isolated by lagging the noise travels through the timber lagging between pipes will help also how old is the pump shud only b a hum if pump ok any more and u need to replace , also u mite like to check speed of pump mite b on max turn down so long ur flow is ok or ur system mite get to hot
Sep 17, 2013 | Water Heaters
Random banging and whooshing sound
New water heater?
http://waterheatertimer.org/New-water-heater-making-noise.html
http://waterheatertimer.org/Repair-water-heater-valve.html
Water does not compress. So each faucet has air chamber located behind wall. Air chamber is usually just a vertical piece of pipe about 18" long with a cap so it never fills with water. When water flows... all the water back to the main supply begins to move toward the faucet. The weight of this water can be considerable. When faucet is turned off, the whole column of water suddenly stops, but weight of water is still pushing forward.
Without air chambers to cushion the sudden stop of water weight, the pipes bang and rattle. With air chambers, the weight of the water pushes up into the air chamber causing the air to compress, which silently cushions the weight of water, but also causes a push-back when water stops moving forward. The push back can then move water backwards where it compresses air inside another air chamber. So the water can slosh back and forth.
IF you have factory-installed heat traps on your water heater, these things have rubber baffles. The baffles hum and rattle and whistle and clog and cause strange sounds that carry through the pipes and water heater and wood joists etc. The water sloshing back and forth can move the baffles and cause noise.
Or maybe you have a check valve that has gotten loose.
Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment and say what you discover
May 17, 2013 | Water Heaters
Loud noises
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
Jul 24, 2009 | Rinnai Digital Remote Water Heater Control...
Noisy water heater blower
There really is no way to do this. If you put a cap you will restrict the air flow which will cause you to have problems with the water heater, same thing if you where to put screen on it. You can try enlarging the pipe to a 3 inch and see if that works. But 15 years in the trade nothing has been made to reduce the noise
Jun 01, 2009 | Fasco Bradford White Hot Water Heater...
Pipes humming in house
From your description, I am guessing you are on a deep well with this answer. I think you have an issue with the well pump. To isolate it do this...........
Turn the main supply valve off to the house. Your well tank should have a hose bib on the well tee. Hook a hose up to that and run it outside. Open the valve to the hose until you heard the pressure click on which activates the pump. After the click close the valve and listen for the hum. If it still hums it is the Well and not the piping in your home.
Will follow-up.............
Please rate this response after testing and Good Luck, Phil
Dec 30, 2008 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Rheem Water Heater Pressure Relief Valve Logo
280 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
