Question about Sony VGN-CR220E/L Notebook
Sony Vaio Display problem
I am using a Sony Vaio VGN-CR220E and starting a couple of days ago, the display has been very dim; so dim that it is hard to even determine if the computer is on. From most angles, it doesn't look like the screen is displaying anything, the only way I can use it right now is connecting it to my tv via the s-video output, or using a flashlight on the screen. I have tried everything I can think of, I have adjusted the brightness, changed the battery settings, plugged it in, adjusted several other display settings, and nothing has worked. I finally went to Sony.com and they said I needed to update my video driver, but that didn't work, then they said to do a system restore, and that didn't help either. Can somebody help me?
  • fixyaGenius Jan 03, 2009
    Sony vaio replace backlight vgn-cr220e; it is 53 weeks old. I use it rarely and gently, but I need it so after working with Sony tech support I know it is the backlight that has failed. I need to know how to replace the defective component and where to buy the part I will have to have. Your assistance will be very much appreciated! Thank you, Christa
  • Anonymous Mar 09, 2009
    Same exact problem.. need help.
    Brigadier General:
  • 6,966 Answers
Since the Sony Vaio VGN-CR220E works except that the display is dark, then it would be safe to assume that it is only the LCD display part that is the issue. Often LCD display (of laptops) are working but only that you can not see the actual display. One way to verify is to shine a flashlight at an oblique angle to the screen, semblance or part of the desktop could be seen s what you have done. If the desktop could be seen (albeit very very dark background) then it could either be the CCF Lamps (cold cathode florescent) or the inverter that powers the lamps.
Often, the defective component would be the inverter. It is relatively easy to replace the inverted. It is sometimes more difficult and challenging cracking open the casing of the display panel of the laptop than replacing the inverter. Additionally, inverters are readily available online. It is also not surprising that inverters for other brands/models would also be used in your Sony Vaio VGN-CR220E .
Of course another possibility is that there is just a loose connection or a cold solder in the LCD panel display's circuit boards.
This would be a good place to start for inverter boards. This is a nice tutorial if you are considering a DIY.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 08, 2008
  • dkwilso Feb 06, 2011
    I have just resolved the very same issue with a Sony Vaio Laptop screen. Only by shining a torch at an anlge across the screen could I see the display (albeit quite faint even then). The external monitor worked fine. I removed the power lead and battery from the laptop. I removed the four screws on the front of the LCD display case and removed the case by carefully prizing it away from the main outset shell using a miniture flat head screwdriver. As soon as the case was removed, looking down to the bottom left of the casing, I could see a connector which had become very slightly unseated from the connector on the left side of the inverter, just millimeters apart from it's pins. I reseated the connection and booted the PC and it works fine! Good luck and thanks!
The wire to the inverter is very short on this model. If you drop the unit it will likely come disconnected.
You can remove the plastic bezel around the screen and this see connector. It is easily reconnected. The store where I purchased my unit said it would cast $200 to replace the screen
Danny
Posted on Jan 08, 2009
  • 26 Answers
This is caused by your monitors backlight blowing out. Call Sony back and tell them your backlight is burned out. Unfortunately, there is no resolution except to replace the monitor portion of your laptop.
I have a sony vaio laptop with windows 7 in italian language and i want to change into english. can you help me please??
Click on the Start Button.
Click the Control Panel. ( Panneau de configuration )
Click Change Display Language (La langue d'affichage)
Click Install/Uninstall Languages (Installer / D?sinstaller les langues)
Click Install display language (Installer la langue d'affichage)
Click Windows Update
Select Optional Updates and Select English. (Mises ? jour en option)
I hope this helps!
Please Rate :)
Mar 18, 2011 | Sony VAIO VGN-CR220E/P Notebook
I have a sony VGN CR-220E which re upgrade to vista ultimate that i could not install the webcam driver ?
According to the spec. it should be OK. Don't forget to download the drivers from Sony.com otherwise it won't work correctly.
Learn more about the Sony VAIO VGN-CR220E/P Model BrandSONY SeriesVAIO CR Series ModelVGN-CR220E/P General ColorCosmopolitan Operating SystemWindows Vista Home Premium CPU TypeIntel Core 2 Duo T7250 2.0G Screen14.1" WXGA Memory Size2GB DDR2 Hard Disk200GB Optical DriveDVD Super Multi Graphics CardIntel GMA X3100 Video MemoryShared memory CommunicationModem, LAN and WLAN Card slot1 x ExpressCard /34 Slot Dimensions13.2" x 9.8" x 1.25-1.67" Weight5.5 lbs. TechIntel Centrino Duo Mobile Technology CPU CPU TypeIntel Core 2 Duo CPU SpeedT7250(2.00GHz) CPU FSB800MHz CPU L2 Cache2MB Chipset ChipsetIntel GM965 Display Screen Size14.1" Wide Screen SupportYes Display TypeWide XGA Resolution1280 x 800 LCD FeaturesXBRITE-ECO technology Operating Systems Operating SystemWindows Vista Home Premium Graphics GPU/VPUIntel GMA X3100 Video MemoryShared system memory Graphic TypeIntegrated Card Hard Drive HDD200GB HDD RPM4200rpm HDD InterfaceSATA Memory Memory2GB Memory SpeedDDR2 667 Memory Spec1GB x 2 Max Memory Supported4GB Optical Drive Optical Drive TypeDVD Super Multi Optical Drive InterfaceIntegrated Optical Drive SpecDVD+R DL Write: 4x max
DVD+R Write: 8x max
DVD+RW Write: 8x max
DVD-R Write: 8x max
DVD-RW Write: 6x max
CD-R Write: 24x max
CD-RW Write: 16x max
DVD±RW: Yes (DVD±R DL/DVD±RW/DVD-RAM)
CD Read: 24x max
DVD Read: 8x max
DVD-RAM Write: 5x max
DVD-R DL Write: 4x max
DVD-RAM Read: 5x max Communications ModemIntegrated V92/V.90 Modem (RJ-11) LAN10/100Mbps WLANIntel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
Jan 01, 2011 | Sony VAIO VGN-CR220E/P Notebook
White screen. what does it mean?
Your LCD might have gone out, call the sony support number for a service request or take it to your local computer repair shop. Hope this helps!
Jul 12, 2009 | Sony VAIO VGN-CR220E/P Notebook
Sony vaio vgn cr200e drive
Western Digital Scorpio WD5000BEVT Mobile Hard Drive - 500GB, 2.5", looks nice. I haven't seen any larger yet.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4322423&CatId=1277
Jan 16, 2009 | Sony VAIO VGN-CR220E/P Notebook
I sold my vaio vgn-cr220e and want to restore it back to original
u can reinstall the windows and use those drivers to put devices to work link: http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220ER
Dec 26, 2008 | Sony VAIO VGN-CR220E/P Notebook
Sony VGN-CR220E/L Notebook Logo
6,991 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
