How do i light the pilot light on Williams P321638 gas wall heater?
  • mbogue778 Aug 30, 2010
    just moved into a place with a wall gas heater - Williams P321638 - and by mistake turned the knob all the way to "off". It was working fine and I just didn't pay attention, thinking I was turning it to "pilot" but instead I turned it off. Instructions say to light the pilot manually, but I'm not quite sure where the pilot burner is or what it looks like. I see something that looks like it could be the burner, behind the big shield. If I don't hear anything like gas coming on when I turn the knob to "pilot" - should I just keep holding a lighter flame to it? Does it take a while for the gas to reach the burner after it has been off for a few weeks>
    Genius:
  • 1,040 Answers
Look at the burners,there will be a pilot.It should be in the front of the burners,in the middle or at one end.Find it first.It will be a small hollow tube.This pilot does not put out a big flame,so don`t worry about it gusshing a flame out.you will want to be ready with a match or a long lighter.A short lighter will do.Turn the knob to pilot.Push down on the knob,and light the pilot at the same time.Now when you do this,hold the knob down,and don`t let off the knob.The thermocouple has to heat up and sense the flame.And it will take about 30 seconds or so.When the time comes to release the knob,do it slow,and watch the flame,if it tries to go out,push it back down for about 20 more seconds.If it will not stay lit,you will have to make sure the thermocouple is touching the flame.The thermocouple has to be in the flame good to heat up.A small steel,or cooper tubing cut off,short,maybe 1/2 inch,can be dropped over the thermocouple to make the flame touch it,and accomplish this task.If the pilot will not light when you push down on the knob,then bleed the air out of the gas line,by holding the knob down far a while,and coming back to it ,to make sure there are no gas fumes around.It won`t be that much gas,just a little.But it is better to be safe.If I can help any more please let me know,and if this was at all helpful,please let them know,thank you.
Posted on Aug 30, 2010
  • 4,924 Answers
This is an indication that your thermocouple is defective. Remove the thermocouple and take it to any hardware or home improvement and they will match the length and provide you with a replacement thermocouple. When you reinstall the thermocouple just make sure the flame on the pilot light is hitting the thermocouple. It may not be exactly like yours but it will be similar.
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
Where is the orifice on a williams wall gas heater 290622
Where the pilot is unscrew pilot tube from pilot assembly and inside there it is
Feb 26, 2013 | Williams (5009622) Ceramic Gas Wall...
Williams wall furnace m#5009622, pilot light stays lit but main burner will not ignite
Check your thermostat most times all u need to do is tweak with the lever or on/off switch.
Nov 18, 2012 | Williams (5009622) Ceramic Gas Wall...
Williams 5009662 pilot light went out, can't tell where to relight
you relight it ,,but it is better you are lyning down to see where to light it,,,but some have a red botton that you push to relight it ,,,like a bbq grill it makes a spark and when you turn the control knob on pilot to light it
Jan 14, 2011 | Williams (5009622) Ceramic Gas Wall...
Williams wall furnace 5009622 the pilot light will not stay on
The thermocouple is bad and needs to be replaced...
The thermocouple is the copper rod that sticks up into the pilot flame and then screws into the gas valve...
they are sold by lentgh so you need to measure the old one when you go to buy a replacement...
heatman101
Jan 06, 2011 | Williams (5009622) Ceramic Gas Wall...
How do you turn the pilot light back on? This is an older model, probably about 10 years old or so.
Move the gas valve knob to the PILOT position and press down on the knob. You will be pressing down on a spring loaded safety magnet. Now light the pilot and keep holding down the knob till the thermocouple gets hot enough to produce electrical current and hold that spring loaded magnet in. This is your safety device. If the heat gets too hot the furnace has a fuse in line with that magnet.
When the pilot stays lit by itself without you having to hold down the button then advance the knob to the ON position. Then go to the wall thermostat and turn on the heater.
HOW IT WORKS: WILLIAMS WALL HEATER
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 11, 2010 | Williams 6508732 Gas Heater
I HAVE A wILLIAM wALL hEATER. tHE PILOT LIGHT IS
The blower is heat activated, it takes more than the pilot. If the burners are on, verify power to the unit.
Jan 01, 2010 | Williams Heating & Cooling
Instructions
The Williams Manufacturer site is www.williamscomfortprod.com The following is a link to the instruction manuals page http://www.wfc-fc.com/literature
Nov 23, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
444 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
