Question about LG Goldstar GWHD5000 wall/window Air Conditioner
My goldstar window air conditioner keeps spitting water out of the vents and making a loud noise, what is it? Please.
    Genius:
  • 1,400 Answers
Hello
Could be the drain hole is clogged up outside.
Its usually located on the bottom r h side.Needs to be unclogged.Use a thin piece of wire or compressed air or even a good blast of water to fix it.
Posted on Aug 30, 2010
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
Jul 29, 2012 | Hampton Bay HBLG5004 Air Conditioner
My goldstar ac is spitting out water and does not get cold what's worng
1. check the filter and clean it while your at it. 2. be certai that the unit is tilted back to the outside about 1 inch or so. Its been real humid of late and thingare are just making a bit more condsesate then ususal ...let me know.. hope it solve the problem
Jul 24, 2011 | Goldstar LG L1004R Window Air Conditioner
My ac is spitting watter by the vent, and making noise i think it happends when the fan inside hits the water that acumulates inside is there something i can do to fix this and make the water go out
The AC fan is blowing the water that has condensed on the cooling pipes.It is possible that there is clogging of dirt in the fins of the cooling pipe'
this results in water logging.The filters must be clogged and dirt has accumalated.Use a good air spray or a water jet to clean.The condensed water must flow to the rear of the unit to drain out .{A/C must be fitted slightly tilted.}.Hope this helps.
Aug 29, 2010 | Goldstar LG L1004R Window Air Conditioner
My window air conditioner is making very loud noises and it is not dripping water outside
No condensation means no freon flow in condensor which sounds like bad compressor which would account for the noise. Replacement would probably be most economical way to remedy.
Aug 12, 2010 | Goldstar KG6000R Window Air Conditioner
Condensation buildup
Make sure the unit tilts towards the outside. If it's installed level or tilted toward front it will not drain properly.
Jun 25, 2010 | LG Electronic Window Air Conditioner
My air conditioner is making a noise and leaking!
mcdevito75 here, Have your A/C looked at by your local A/C repair shop. Sounds like the compressor is makeing the noise (expensive repair if so)
Jun 22, 2010 | Goldstar KG6000R Window Air Conditioner
Doesnt cool room as in prev years
yes the side vents need to be outside the window and if they aren't - the unit will not cool correctly.
Hope this helps.
Jun 08, 2010 | Goldstar WG5000 Air Conditioner
GoldStar model GWHD5000
Make sure that the unit is properly mounted in the opening (I take it it's in a window) and that it is level or at least not tipping inward as in the outside being higher than the inside. If unsure about how to mount it properly, consult your owners manual. Your installation should be reasonably close to the illustrations.
Jul 13, 2009 | LG Goldstar GWHD5000 wall/window Air...
LG Goldstar GWHD5000 wall/window Air Conditioner Logo
534 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
