Question about Maytag Dryers
The dryer is not turning where do and how do get to check the belt, if it is broken or maybe sliped off?
    President:
  • 3,074 Answers
You will have to remove the front panel. screws are on the inside of the door, may be two on the bottom corners, with a flat tip screw drive gently pry up on the top corners. remove panel disconnect door switch, the belt goes around the drum to the motor and has rollers on the back of the drum. I even think on the backside there is a rest button. Hope this helps Tim
Posted on Aug 30, 2010
Drer heats but drum does not turn
Hi, it sounds like the drive belt is sliping,broken or something connect with the drive is sliping or broken. If you can see the motor and belts turn it on and the fault should reveal itself
Good luck
Aug 04, 2014 | Kenmore Dryers
Dryer just stopped wont turn
More than likely a broken belt. A fairly easy fix. Disconnect Dryer electric by shutting off the breaker. Then remove the front panel that surrounds the door. There are ususally a couple of screws on the bottom and you have to pot the top. Get a belt off the net or from a appliance dealer. The belt slips around the drum over the motor shaft and on a tension Idler wheel. Pop is back together and you good to go. Try checking You Tube and see if there is a video on dryer belt replacement. Good luck! :)
Oct 07, 2012 | Maytag MDE308DAYW Electric Dryer
My dryer doesnt work. the tumbler doesnt turn. when you push the start button it sounds like its going to start but it doesnt move
hi check the belt maybe broken or if you just hear humming maybe motor. dose it heat at all? jim
Oct 11, 2010 | Maytag Dryers
My dryer drum wont turn but i do have heat ,the motor is running and the belt is not broken...help!
i would check the belt idler arm under the drum,maybe it jumped off-mike
Feb 17, 2010 | Kenmore 63942 Dryer
Dryer heats up but the inside doesn't turn.
a dryer will not turn if the belt has fallen off the motor or if it has been broken    replace the belt
Nov 05, 2009 | World Imports Belle Foret N30002TB...
My kenmore dryer's drum does not spins. I checked for the belt and it's fine. Where do you suggest I check?
the drive motor if its not turning then the drum wont turn, also if its sliped the belt off thats another reson why and one more thing to look at is how tight is the belt on the drum,,, is it just sliping round it? is the drum very tight to turn by hand? are the drum bearings jamed up, is any thing stuck behind the drum? ??? like one of the kid's?
i hope this is helpfull to you
Oct 23, 2009 | Kenmore 63942 Dryer
The dryer will not turn on. Timer is ticking I think it may be the start button
Could be the start button, but also could be a broken drum belt or the belt maybe has slipped off the motor pulley or idle arm pulley. Also could be a bad motor. Check to see if the motor is turning first and the belt is on properly.
Sep 26, 2009 | Kenmore 63942 Dryer
Removing the back of the dryer
to get at belt you will need to get true the front of dryer.When you have top up there should be 2 screws on both inside corners on front panel remove them and lift up and towards you the front panel should come off.After that look under drum .Sounds like your belt sliped off the idler pully you can then put belt back on and reverse the steps.If any more help needed feel free to ask hope i fixya:)
May 21, 2009 | Kenmore 64852 Electric Dryer
Dryer is noisy. rollers are new. sometime the dryer starts fast
I would say the belt may have sliped off the pully.Make sure the belt is on correct.
May 08, 2009 | Kenmore 73952 Gas Dryer
Clothes dryer
dryer won't run, but hot air blow and humming when turned on
Belt is off, idler is off or broken. Replace the belt and idler. Make sure it is installed correctly with tension on the belt. It will take care of your problem
When I try and start my ge dbb3300eaoww dryer it buzzes as if it wants to start if I spin it with my hand it will work. I put a new belt on it and it does the same thing.
Motor start switch is bad. This is typically replaceable with out replacing the motor.
Will take care of the problem.
My drum will sometimes stop turning in the middle of a cycle, and the motor just hums. I pause the dryer, open the door, rotate the drum, unplug and plug the electrical, and then it will usually complete the cycle. Does that mean the belt is "occasionally" slipping? How do I check this?
Replace the belt. It has stretched to the point it no longer can carry the load. Should consider replacing the idler at the same time. This will take care of the problem.
Sep 15, 2007 | Dryers
Dryers Logo
43 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
