Question about ASUS Eee 4G Notebook
Installed Windows xp now the web cam is not recognized
Installed Windows xp and everything works wonderful with the exception of the webcam ... It is as if it does not exist or recognized ... is this a driver issue ?
  • 101 Answers
Hi before you install any of the drivers please install SP2 for XP .
Posted on May 10, 2008
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
Cant get computer to recognize web cam
The Quickcam Pro 9000 is only compatible with PC, Windows XP SP2 at least.
If your virtual PC runs Windows 7, there is a known issue running it in Windows 7. If this is the case, I suggest to contact the manufacturer.
There is one made for MAC though; QUICKCAM vision PRO. Manufacturer's part number is 960-000254.
Hope this helps! Please don't forget to rate or vote. All the best!
May 07, 2010 | Logitech QuickCam Pro 9000 Web Cam
Windows 7 does not recognize the Web Cam
instal Picasa 3, it recognizes all web cam without any driver
Nov 05, 2009 | Creative Labs Live! Cam Notebook Pro...
My webcam problem,i have aspire 4530,i install xp not vista..my
acer uses three webcam hardware. bison suyin chiconny www.acer.com. go this link and find your model. download 3 driverss and try. you will find which one is your
Jun 03, 2009 | Acer Aspire 4530-5889 Notebook PC
Vupoint FS-C1-VP scanner installed
i have vista home and mine worked fine until i installed a web cam and then it just gave up. But now it works great - here is what i did
unpluged both the scanner and the web cam
uninstalled everything to to w/ the scanner and the web cam.
Installed the driver from the CD and restarted my machine
Install the Photo 6 software
plug in the scanner - works like a champ.
have not reinstalled the web cam
Oct 02, 2008 | Office Equipment & Supplies
WebCam and sd card reader
Hi have you installed service pack for xp, if not install SP 2 for XP which should solve the problem.
May 08, 2008 | ASUS Eee 4G Notebook
Web cam need pack2
TYPE WINDOWS XP SP2 IN YOU BROWSER.DOWNLOAD SERVICE PACK 2 IT WILL INSTALL ITS SELF.RICHARDM69
Dec 08, 2007 | Logitech QuickCam Pro 5000 Webcam
Trying to install my web cam
I have windows XP professional OS and i have connected Veo Stingray web cam after installed driver its do's work,
I want sollutions if anybody can help me.
Please help me out.
Thanx
Oct 11, 2007 | Veo Connect Webcam
ASUS Eee 4G Notebook Logo
306 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
