Question about Refrigerators
Came home to find my frigidaire side by side warm and everything melted. I can hear the compressor buzzing, trying to kick on. All fans working, clean coils, not frosted up. Any one know how I can I qualify the compressor or have any other ideas of what to check?
  • 2,272 Answers
If the compressor buzzing then 1) The compressor runs by start up capacitor.On some side by side models there is start up motor instead of capacitor.both functions the same.the motor or capacitor.If this fails the compressor will not run or will start to kick on. 2) The other possibility is relay.There is relay beside the compressor.If this relay is faulty then it will not let the compressor to function properly. 3) The other possibility is fan beside the compressor.If this fan is running slow then it will make the compressor go hot and get short faulty. 4) The other cause can be faulty compressor itself. --------- The problem which you mentioned" frigidaire side by side warm and everything melted" ,this all relates to faulty compressor.But compressor supporting motor, capacitor,relay,fan and its connections needs to be checked first by meter.If all checks out ok and working then yes its faulty compressor and that needs to be replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
MZD2766GES compressor not firing
Is your compressor giving sounds like a buzz followed by a click periodically? Is the compressor exterior warm/hot? Most likely the compressor start relay assembly is bad, or the compressor is locked up, (frozen internally). If you connect an amp probe to the red wire of the compressor, and the momentary reading meets or exceeds the LRA rating on the compressor tag, most likely the compressor is at fault. Pleazer Appliance...
Apr 09, 2014 | Maytag MZD2766GES Side by Side...
We just came home and found water on the floor....the freezer had melted and the frig is warm...we threw everything out....we cleaned the dust behind the frig...what do we do next?
Do you see anything happening with the refrig. is teh compressor running..do you hear any fan on?? or perhaps every couple of minutes their is humming/buzzing sound floowed by a click??
If you hear nothing at all going on i would suspect the thermostat or the defrost control board is the problem,If ya hear a buzz/click then what would be needed was the relay/overload on the compressor
Reply with what exactly your experiencing and i could help ya narrow it down
GENE
Sep 18, 2011 | Maytag MSD2756G Side by Side Refrigerator
The fan runs but compresser will not kick on
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 08, 2011 | Frigidaire FRS3R5EMB Side by Side...
Side by side refrigerator not cooling removed the back cardboard panel and cleant the dirt the fan is working fine but the compressor is not kicking in. it is luke warm and i can hear clicking sounds off...
I hate to be the bearer of bad news but if your hearing the humming clicking sounds chances are you have a bad compressor. You can change the relay out and it may work but more than likely the reason it would have went out is becasue the compressor blew it out. Frigidaire is notorious about this problem. I'm sorry.
Nov 02, 2010 | Frigidaire Refrigerators
Refrigerator and freezer both are not working. fan in back of unit running but internal fan not running. i also cannot hear the compressor kicking on.
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Yesterday started hearing a buzzing sound from the fridge. Came home today with a pool of water in the kitchen coming from the fridge. Opened the freezer, ice is melted and inside is relatively warm....
I would check for a bad starter relay first unless you can verify that the sound is comming from the compressor. How to check stuff> http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 16, 2009 | Frigidaire PLRS267ZAB Side by Side...
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
