Question about Hoover HTC243 Top Load Washer
Our hoover 800 toploader go into pause mode between cycles, any tips?
  • tony641 Aug 30, 2010
    Thanks for that, Ill try uplugging and get back to you if that doesnt work.
  • 5,081 Answers
Unpluggin the machine is pretty much the only way to reset it.Leave it unplugged for a couple hours if that doesnt work its most like a control board issue
Posted on Aug 30, 2010
  • INDIRA KUMAR
    INDIRA KUMAR Aug 30, 2010
    Please rate and accept my answer if satisfied.
Enter diagnostic mode in mod 11028002010 toploader he washer
Washer topload diagnostic mode. - YouTube
? 5:00
https://www.youtube.com/watch?v=jipYd_qeCqs
Jun 17, 2014 - Uploaded by Al Fixit
How to put kenmore washer into diagnostic mode. ... How to Use HE Top Load Washing Machine: Informational Tips From Sears Home ...
Entering Diagnostic Mode in a Whirlpool Vertical Modular ...
? 1:02
https://www.youtube.com/watch?v=7kWrIPaWLUM
May 8, 2012 - Uploaded by SamuraiRepairman
Shows how to enter diagnostic mode in the Whirlpool VMwasher. Created on May ... The first was no error codes. the second said that we had an unbalanced load. I'm not sure ... I had a repair person out to my house he reset the computer panel and it worked. Now its ... washer. Raise the top panel to get it.
Diagnostic mode for Kenmore Elite Oasis HE Top Load ...
Dec 12, 2015 | Washing Machines
My hoover 800rl top load washing machine does not progress beyond the fill cycle. once the water has reached the set level the start/ pause light goes from solid to flashing and nothing progresses form...
Check owner's manual. The light issue should be covered. Is it possible the tub is over filled? If so the level indicator switch is not working right. I'd unplug for overnight to see if the electronics will reset. Service Technician may be needed.
Feb 13, 2015 | Hoover Washing Machines
Frigidaire washing machine model number 137168300a stuck in pause mode
Good Afternoon Friend, this is Z. Thank you for your inquiry!
If you are receiving an error code PAUSE, it commonly indicates that the door of your washer is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If these basic troubleshooting tips prove ineffective, try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. If the issue persists, then your washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 12, 2014 | Frigidaire Affinity ATF7000EG
My Hoover Elite 1210 toploading washing machine seems to make a horrible off balance sound on the spin cycle - even when there is a small load on. What can I do to fix it?
Could be bearings or more likely the concrete weight at the bottom of the drum is loos give it a shake from under to check...Good luck
Feb 09, 2011 | Hoover Washing Machines
My topload Roper washer cycles fine but stucks in rinse stage. It makes a noise on that stage. I manualy put it in spin mode (skipped the rinse) and it works from there. Please help.
Your timer is bad. There must be a pause in the timer for the neutral drain transmission to lock in.
No Pause.
No Spin.
To double check this,when the timer gets to the Spin cycle, open then close the lid.
If it starts to spin at that point the timer is bad.
Jan 09, 2011 | Roper Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Hoover 800 RL toploading washing machine
if you use liquid fabric softner that is what it is sort of looks like grease what happens is that softner gunks up and gets up under the agitator then when your lighter clothes are washing it shows up you need to take some stuff called washer magic and just follow the directions on the bottle
Jan 01, 2009 | Washing Machines
My Hoover Model Not listed/stops during the cycle
the cycle timer is beginning to sieze because it needs oil. disassemble washer to the point where you can apply small drops of 30W machine oil to the timer's bearings
May 20, 2007 | Hoover HTC243 Top Load Washer
Hoover HTC243 Top Load Washer Logo
47 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
