Question about Cameras
I recently recieved a Canon Rebel Xti as a gift alot with a Sandisk extreme III 2.0 GB memory card. I see the CF opening on the camera but i have no idea how to get the memory card into the computer, it seems so small to fit into the cf opening. It's probably a simple answer but it's puzzling me. Any help would be greatly appreciated
    Sergeant:
    Champion:
  • 333 Answers
Hello there,
there are clear pictures on page 29 and 29 of the instruction manual. The card will only go in one way -so don't attempt to force it .
http://safemanuals.com/annexe_Instruction%20Manual_CANON_EOS%20DIGITAL%20REBEL%20XTI-_E.htm#
If this works, please rate 'fixya'
If it does not then come back to me and we can try something else!
Posted on May 08, 2008
Canon rebel xti digital camera mem. card will not lock into place
It seems that the CF reader mechanical assembly part has loose or out of place an internal part.
It may be caused by excessive force in pushing/pulling a CF memory card, or due to a manufacturing issueof the camera.
The solution is to open the camera, and check what is causing the problem and fix it.
If it's under warranty, I do recommend you to return it. If not, then you will need to pay for its repair, or do it yourself if you have experience, skills and patience in fixing electronic devices.
Such repair will require some philips screwdrivers, a soldering iron, soldering wire, and a st of tweezers.
There are in internet some guides to open and disassembly Canon XT 350D or Rebel 300d cameras. The disassembly process with the XTi 400D is very similar. You can Google fr such guidelines.
Best regards,
May 24, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Memory card will not lock into down position. will just bounce back up
It seems that the CF reader mechanical assembly part is loose or it has out of place an internal part.
Best regards,
Why does the word, ''busy'' pop up on the canon rebel xti?
This is the camera writing to the CF memory card. Perhaps your card is a lttle slow, so you will see the message. I use the Sandisk Ultra II CF, labelled as 15Mb/sec and it is very very fast indeed - I don't have any lag with my XTi. Try a different CF, if it is fast enough, the message will go away. Ensure you format the card on the camera too.
Apr 13, 2009 | Canon EOS Digital Rebel XTI Digital Camera
Not able to read contents from Memory disk
I)try this rightclick on the drive and select the option 'Explore'
Thanking you
M. Sridhar
Jan 01, 2009 | SanDisk Extreme III 2GB Secure Digital...
Err CF
I had the same message on my EOS/Rebel XTI and the camera shop concluded that one of the pins where the card is inserted into the camera had come loose. They sent the camera back to Canon for repair. Luckily, it was still under warranty at the time.
Chris
Jul 04, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Err CF
Observe the connector inside camera, using a flashlight. If there is a bent pin take the camera to service immediately. Don't turn it on any more as we did in one similar case - creating a short circuit that damaged the camera electronics and voided the warranty.
If no visible problems, remove battery and leave it out overnight.
Jan 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Rebel XT will not work with new faster CF cards.
Check the volume and speed of memcard, maybe it is not compatible. error 99 is an indication that a lens or shutter curtain is not working, so i cant see any connection with the memcard problem. Check your camera memcard compatibility.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
CF Card not being detected
Jerseygirl98 does your computer reckonize the card if not it may be a bad card. That does happen..I the computer does right click on the card and rename it .JERSEYGIRLCAMERA
THEN LOOK FOR IT..Try to format the card in the computer..No luck just get another card..
Dec 24, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
49 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
