Question about Casio FX-115ES Scientific Calculator
Have a Casio fx 260 solar scientific calc. and don't know how to enter a negative exponential term. I have an "EXP" buttom (the one used for exponential terms, but don't know what to do to enter a negative exponent.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Use the (-) key (far left column, above RCL) to enter the negative sign.
Posted on Aug 30, 2010
How to use thefunctions on the 260 fx solar
Try them by yourself or read the manual. You should be able to figure out most of them.
Aug 25, 2014 | Casio FX-260 Solar Scientific Calculator,...
The math problem is x2= 85-84 cos25 and it doesn't work on the fx-260
85-84cos(25 deg)=8.87015 and I do not see how you get 3. If angle is in radians the answer is 1.73896. Make sure your calculator is configured to use the right angle unit (radian, degree or gradian).
Jan 19, 2013 | Casio FX-260 Solar Scientific Calculator 1...
How to solve equations with two variables by usin CASIO fx901 calculater? eg- 6x+9y=2700 5x+4y=1560
The FX-901 calculator seems to be the equivalent of the FX 260 Solar sold in North America. It does fraction calculations, permutation, statistics but lack the Equation Solver.
You cannot use it to solve equations.
Casio Scientific calculators that can handle equation solving are the FX-115 and FX-991.
Simplify your first equation by dividing all its terms by 3, then use elimination to carry out the solution by hand.
Sep 02, 2012 | Office Equipment & Supplies
I need step by step instructions on using Casio fx-115ES ee or exp burron.
The equivalent of the EE or EXP button on the Casio Fx-115ES is marked as x10^X. It is located at the bottom right of the key pad left of the = key.
To enter the power of 10 in a number written in scientific notation, you press the x10^X button followed by the exponent. If the exponent is negative you press the change sign key first [(-)] , then the one or 2 digits in the exponent.
Example Enter the mass of the proton m_p in kilograms
1.6726217 [x10^X] [(-)]27 [=]
In grams the value above is multiplied by 1000.
or
1.6726217 [x10^X] [(-)]24 [=]
Since the calculator has the physical constants (the FX-991ES definititely has them)
  1. Display the proton mass in kilograms
  2. [SHIFT ][7] to open the constants catalog,
  3. type 01 for the proton mass, then press the [x^-1].
  4. Divide the result by 1000
  5. You should get 5.978638635 x10^23
Feb 07, 2012 | Casio FX-115ES Scientific Calculator
I need help calculating how many protons are in 1gram
The equivalent od the EE or EXP button on the Casio Fx-115ES is marked as x10^X. It is located at the bottom right of the key pad left of the = key.
I can't find the EXP button on my Casio fx-83GT calculator...help?
Your question is slightly ambiguous.
If you refer to the exponential function (power to base e = 2,7182818...), the key sequence is [SHIFT] [ln]. (rightmost button column, two rows below the ON key).
If you refer to a key allowing to enter powers of 10, like in 3,14 x 10²³, see the button labeled
its located in the bottom button row, center column.
Feb 24, 2011 | Casio FX82ES Scientific Calculator
How do i calculate the pH of a solution on the casio fx-260 solar calculator?
General shortcut.
If the concentration is of the form 1* 10^ (-a) where a is an integer between 0 and 14, the pH is given by a.
c= 1.* 10^(-5), pH=5
c=1.*10^(-11(, pH=11.
For other values, ex: c=3.68 *10^(-8)
pH: 3.68 [EXP] [+/-] 8 [LOG] [+/-] Result is 7.434
Above, the [+/-] key is the change sign key, just above the [7] key.
Mar 13, 2010 | Casio FX-260 Calculator
How do I input a mumber in scientific notation?
The structure of a number in scientific notation is as follows
one digit [decimal mark] several digits power of 10 (- sign if needed) up to two digits for the exponent.
d.ddddd [10^] (-) dd
To enter a number in scientific notation you need to use the [EXP] key, between the [.] and the [=] sign, on the bottom row of keys.
Ex: Avogadro's number (do not worry if you do not know what it represents)
Na= 6.02 x10 ^23
6.02 [EXP] 23 [=]
Electron charge 1.6 x10 ^(-19)
1.6 [EXP] [+/-] 19 [=]
The [+/-] key is the change sign key, in the first column of keys, between the fraction key [a b/c] and the [7] key
Jan 14, 2010 | Casio FX-260 Calculator
Is there a way to fix the casio fx 260 solar to display numbers in scientific notation Like 3 x 10(raised to the 2nd power)?
This can be done by setting the calculator to the right MODE. Press MODE 9 to turn on scientific notation. For example, compute 1 / 200 = and you will see 5 with a -03 exponent in the upper right. Press MODE 9 again and it will be displayed .005
To enter numbers in scientific notation use the EXP at the bottom. To enter .005, press 5 then EXP then +/- then 3. You will see it displayed. Then you can perform calculations with this entered number.
Oct 01, 2009 | Casio FX-260 Calculator
Does the fx-260 SOLAR do exponential calculations?
Yes it does. All scientific calculators do logs, power, roots, exponential, trigonometric functions. Most do also hyperbolic and inverse hyperbolic functions.
Hope it helps.
Aug 16, 2009 | Casio FX-260 Calculator
Casio FX-115ES Scientific Calculator Logo
267 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
