Question about Casio PRG-40T-7 Pathfinder
How to install batteries in a casio pathfinder pag40-3v
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
I'm not 100% sure on this procedure, but you can download the complete manual by noting the four-digit module number from the watch back, and go to this link:
http://world.casio.com/wat/download/en/manual/
Good luck, Bill
Posted on Sep 01, 2010
Casio sea pathfinder sp60d reset
You need to open the watch and cortocircuit 2 points into the watch machine.
TicTacArea.com is Officla Casio Dealer
Casio Watches
Aug 19, 2014 | Casio Sea Pathfinder Triple Sensor SPF-60
I just changed the battery on a Casio watch A158W and now the alarm and hourly chime doesn't work.
The replacement battery may not have been installed properly. It can be a tricky operation. Also, the replacement battery could be ng.
May 31, 2013 | Casio Pathfinder PAG40B-2V wristwatch
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    Casio Pathfinder Digital Compass will not calibrate
    http://pathfinder.casio.com/support/manual/
    find your watch and use the manual. if there is no solution then take it in for repair. any Casio retailer should have repair center information.
    Jan 25, 2009 | Casio PRG-40T-7 Pathfinder
    CASIO SPF40 battery replacement
    "AC" means All Clear. This terminal should be marked somehow. Use a magnifying glass to get a good look at what you are working on. My Casio had an arrow pointing to four copper leads. I used a paper clip to connect the AC terminal (I just picked one of the four) to the + side (usually the "up" side) for a couple seconds and my Casio Sea Pathfinder model 2273 powered right up. See the following link for more guidance.
    http://www.geocities.com/watch_crazy/battery/battery.htm
    Feb 24, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Casio PRG-40T-7 Pathfinder Logo
    1,169 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
