Question about Ingersoll Air Tools & Compressors
Have ingersoll rand p175 w-w compressor when engine is started as long as a ball valve is open on air output line is open on exaust side of air/oil canister engine will run rough but will run. As soon as i push button to idle engine up for pressure, engine loads up and quits. Engine has had a tuneup. have taken piston valve off of exaust line and cleaned out a little bit of rusty water. Was working fine and all of a sudden quit working. if you have diagrams of system and diagnostics data please send.
I have a similar problem with my compressor. Have you had it repaired yet/ If so, what was the problem??
Posted on Sep 15, 2011
I have a ingersall rand 2475e compressor that the valve that the small copper tube goes to started leaking. replaced the valve and put back together and now pop off valve on the line from the compressor to...
Sound like a bad receiver tank check valve. Located in top of the tank and the pop off valve is screwed into it. If check valve is good you need to remove the heads and check the finger valves. I believe you'll find your problem in the check valve
Sep 12, 2011 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
After compressor turns off it leaks air from pressure switch
Sounds like you have a tank check valve leaking. It is located in top of the tank. The copper discharge line from the compressor goes into the check valve. Make sure there is no air pressure in the tank. Then Remove the large copper discharge line. Also remove the small copper line from the side of the check valve. Once the lines are removed you can remove the check valve. Most of the time the check valve needs replacing. Sometimes they have large pieces of trash holding them open.
Aug 31, 2011 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
Ingersoll-Rand Air Compressor P185WJD why would the pop off valve on the air separator keep popping off
its because the compressor is not unloading { going above 120psi} you need to check the air signal going to the unloader valve located on top of the screw, it should start putting out air at about 90psi to close the unloader. another thing is if you are getting oil in the air coming out of the front ball valve the seperator element is bad thats the filter inside the tank the pop off valave is mounted. you can check the air signal by fethering ball valve to run the machine at 90 psi the diconnect small air line on unloade to check for air signal coming from regulater
Jan 06, 2011 | Ingersoll Air Tools & Compressors
1.fault code 970- compressor runs for few minutes and trip, why. 2.compressor is not burnt but also not working well.
Check the intake filter. Check the output line for leaks. remove pressure line and air intake from compressor and inspect reed valves. Dust and oil can hold the reeds open.
Aug 09, 2010 | Ingersoll Rand Compressors 5-HP,...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Unloader valve keeps opening and closing during pump operation. does not give a continuous discharge, as when the ball valve is stuck open. seems that when the pump reaches max output pressure that the...
Sounds like the cutoff valve is failing to cut power off to the compressor drive motor, while it activates the unloader.--- I'd consider looking closely at the contacts, or replacing the cutoff.
Nov 13, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Portable Compressor Model # P175 WD runs fine builds air pressure but when turned off it belches pump oil out air intake.
your ring on the piston or your cylinder is scored. you'll need to have or do it your self and have the cylender hone and new rings installed. check to make sure your cylinder is not to Far damaged. good luck
Oct 15, 2009 | Ingersoll Air Tools & Compressors
Air Tools & Compressors Logo
296 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
