I use a mouse rather than the touch pad, and the cursor sometimes takes on a life of its own, jumping to different parts of the screen - even when I don't go anywhere near the touch pad. Can you please suggest a fix?
    Sergeant:
    Champion:
  • 230 Answers
Download and install this application. It is called touchfreeze, it disables your touchpad while typing and regains sensing motions when keyboard is not active.
Posted on Aug 30, 2010
Gateway HDMI laptop T series charger output 19 vgets v.hotbut works . burser pointer starts jumping frm place to place on screen dificult to control ?
run it in battery to see if fixes cursor problem
also try a different mouse see if that makes the cursor move correctly
this way you see if its the mouse or power supply
might also a touch pad problem anything that controls the cursor
May 07, 2015 | Gateway Computers & Internet
On my CF-51 the touchpad is erratic and occasionally the screen cursor will jump. The OS is Windows XP. Everything else works perfectly.
I had similar issues with cursor jumping even while using a mouse.
Very simple & quick fix is to simply "disable" touch pad through "start up" mode use a mouse.
You have to disable in start up menu or pad will re-enable itself next time you boot.
I never liked a mouse before being forced to use it .... now it's not so bad.
Jun 22, 2011 | Panasonic Toughbook CF-51 Notebook
Frequently during the typing of a document my cursor will jump to a completely different part of the document and until I lookup I'm typing in the wrong section. I'm not touching the internal mouse pad....
Be very careful about this. When I used my laptop all the time the same thing would happen from time to time.
If you touch the mouse pad at all it will move your cursor. Even lightly touching it with part of your hand can do the trick. Its best to hold your hands as high off the laptop as you are comfortable with. Try this and see if the problem persists.
Apr 07, 2011 | Dell Latitude E4300 Notebook
I have a Dell Inspiron 1545 which has three problems, the battery discharges faster than when used by another computer of the same make, the screen lighting often blinks severally before it completely goes...
http://download.cnet.com/ccleaner/
run crude cleaner to get the flicker and speed the laptop up
get a new battery... if discharges too fast.. like less than 45 minutes
cursor jumping around.. watch your touchpad..
commonly you are touching the mouse pad during some keystrokes
you can set the mouse pad sensitivity downward under control panel--> mouse---> synaptics mouse pad sensitivity also
Jan 21, 2011 | Computers & Internet
Jumping cursor
Open touchpad properties, touchpad settings section, enable Touchcheck, set the slider to minimum setting Click OK
TouchCheck disabled the touchpad while typing
Jul 10, 2010 | Dell Latitude E4300 Notebook
When I tap on the touch pad on a HP Pavilion dv7 cursor jumps
Go to your control panel and double click on your mouse icon to get to your mouse properties. Go to "Pointer Options" and make sure that the "snap to" box is unchecked.
Mar 21, 2010 | HP Computers & Internet
When typing the curser jumps to a different position
This is because you are touching the touch pad with your palms. when typing avoid contact with the mouse pad in your laptop. I hope this will help. Thanks.. Please rate this!!
Aug 16, 2009 | Acer Computers & Internet
Cursor jumps around screen when typing
your dell laptop are supposed to have a program on touchpad, if you dont have that in your system then the touchpad is jumping
Jun 17, 2009 | Dell Latitude D630 Notebook
Mouse moves on its own
Your palm might be brushing on the touch pad while you are typing that is probably why the cursor jumps to a different location. as for disabling the touch pad I think that it is not possible unless you install a synaptics driver for your laptops touch pad.
Apr 01, 2009 | Gateway Laptop Keyboard for MX6930,...
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
