Question about Kenmore Sewing Machines
I have a Kenmore sewing machine model 158 14101. It will sew straight, do a blind stitch and occasionally do a stitch for sewing elastic. It seems to ignore any other stitch setting although the special stitch knob turns as does the special stitch variegator. Please help.
  • 28 Answers
SOURCE: Blind hemmer
First get a new quality needle of the right size for your machine use a good quality hemming thread and check your tensions. If this fails to fix the problem you will probably have to have the timing checked.
Posted on Jun 07, 2008
  • 69 Answers
SOURCE: Kenmore Sewing maching 158 15510: sewing mechanism
You put the hook (the half moon thing with a sharp point on it) in the machine by placing it opposite the little curved bar. Make sure it is seated properly on the ridge. The you take the race, the circular part with a small plate on the top and place that over the hook(the plate side will be facing up). It will only fit a certain way, it could have a slot that a notch fits into (that is usually how it goes). Then slide the arms over it and they will snap into place. Once done, turn the handwheel and make sure everything moves smoothly. If not, you'll need to start over as something isn't seated correctly. Then you can install the bobbin case as usual.
Posted on Mar 01, 2009
sburtenshaw1
  • 5 Answers
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
Posted on Feb 13, 2010
  • 1116 Answers
SOURCE: Can I do free motion sewing on a Kenmore Ultra
If you can lower or disengage the feed dogs you can stitch free motion.
If the the feed dogs cannot be adjusted as described, you can set the stitch length to zero.
You can also tape an index card over the feed dogs and punch a hole where the needle needs to enter the needle/face plate.
A darning or free motion foot is needed.
Take a presser foot with you when shopping for the foot as it is important to match the shank length.
Newer sewing machines are low shank and the older ones long shank.
You can also order online at Clotilde (see "which foot to use" for a guide).
Posted on Feb 20, 2010
  • 68 Answers
SOURCE: Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Posted on Feb 25, 2010
Stitch width knob
What's the model? Do you have the stitch selector set on straight stitch, or on a stitch with a width component, like a blind hem stitch?
Some machines consider straight stitch to be a zigzag stitch of width=0, while others have separate settings for a straight stitch and a zigzag (or other) stitch.
Feb 11, 2014 | Elna Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
Does the singer 3116 come with a blind stitch for hemming
Most sewing machines come with a blind hem stitch. It is the one that looks like several small zig-zags then occasionally a large one, or several straight stitches then a large zig-zag. Either will result in an invisible hem.
Some machines have a special foot but it is not necessary, mine does not. There is however a special way of folding the fabric.
See http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faqh/000000/000000/000017/faqh000017_000.html?reg=eu&c=eu_ot&lang=en&prod=hf_rs240250260euk
Or also an instructional video: http://www.ehow.com/video_4407404_machine-sew-blind-hem.html
Hope this straightens things out for you!
Nov 06, 2011 | Singer 3116 Simple
I am trying to alter a swim suit, and I need to use a stretch stitch. Does the Singer model 2638 have this feature?
Here is the stitch selection page from your manual
I would suggest that you use the stitch called "elastic overlock" using a stretch needle, you need a ball point tip on the needle to press between the elastane fibres in lycra. A stretch needle is blue, coated with a substance that makes it easier to stitch these types of man made stretch fibres, often size 75. If you can't get one of those, then use a ball point needle, size 70 or 80.
You need a stitch with forwards and backwards movement so that the stitching doesn't break under stress. Your machine also has a stretch straight stitch and this would be a forwards and backwards straight stitch so this will work too but can look a bit 'heavy' sometimes. But even triple zig zag narrowed down will work often.
If you are sewing leg edges with lycra, shop made garments will have clear swimsuit elastic sewn into the seam using a coverstitch overlocker, you'll never get as good a result with a regular sewing machine but you can get a reasonable finish with practice. This elastic is available to buy, you might want to use the overlock stitch to attach it to the fabric edge, stretching as you go, then turn it to the inside and use a stretch twin needle and straight stitch to top stitch from the outside, stretching the fabric as you sew.
Trust this helps you a little, 4 thumbs up if so. :-)
Jul 13, 2011 | Singer 2638 Mechanical Sewing Machine
Can someone tell me which stitch to use on the Bernette 65 to sew elastic? I can't seem to find a stretch stitch. Thanks.
Are you sewing through elastic such as joining the two ends of a loop of elastic in a waistband?
If so, just your straight stitch or three step zig zag works fine.
If you are actually seaming on knit fabrics then you need a stitch with forwards and backwards movement to allow the fabric to give when worn without breaking the thread in the seam. tally_girl_8.jpg If this is your machine and you want to stich jersey or knits, I'd use the overcasting stitch, fifth from the right. or the tricot stitch to the right of it, this stitch is good for attaching rib trim around necks and sleeves.
Your sewing machine manual should also give you information on which stitch is used for what. I also like the Singer Sewing Manual book for good general sewing information.
Mar 09, 2011 | Sewing Machines
Hi i want to buy a sewing machine wich one is best. kenmore or brothers sewing machine
I would prefer Kenmore, enmore makes perhaps the largest selection of mechanical machines. The very cheapest Kenmore sewing machines, like the Kenmore Mini (*est. $100) and Kenmore 15208 (*est. $120), stick with a four-step buttonhole, and have just six and eight stitches, respectively. The Kenmore 15212 (*est. $150) and Kenmore 15218 (*est. $170) both have a one-step buttonhole. The cheaper Kenmore 15212 has 12 stitches. The slightly more expensive model has 18 stitches, including a smocking stitch, overcast and elastic stretch stitch in addition to the basics. Both Kenmore sewing machines are good, basic models, say reviews. Both have just a 90-day warranty, however. Bear in mind that Kenmore sewing machines are made by different Asian companies each year, resulting in varying degrees of quality; this also explains the low prices. Some users report difficulty with tension and light fabrics.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2010 | Kenmore 19365 Computerized Sewing Machine
Sewing machine straight stitch is not straight
It sounds like it is making a blind stitch, does it look something like this? -----v-----v-----v-----v-----v If so it might be on the blind stitch setting instead of the straight stitch! ;-)
Oct 11, 2007 | Sewing Machines
Sewing Machines Logo
55 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
