Question about Whirlpool Washing Machines
Washer tub is out of balance empty of clothes
  • 10,865 Answers
Hello. Go ahead and put clothes into the machine. It will not self balance when empty but once clothes are added and you start it up it will self balance. IF you do these things and the machine is still out of balance you will have to check the 4 suspension rods on the outer tub to make sure that one of them is not out of place or broken. You may choose to call a repair man at this point. J.
Posted on Aug 30, 2010
GE Profile washer, tumbler out of balance?
Empty, fill with water only run through spin cycle. Replace clothes
do not overload and try to distribute clothes in an even weight pattern over the tub bottom.
Sep 04, 2014 | GE Profile WPRE6100G Top Load Washer
Washer clothes
Your load is out of balance.
If you have a heavy item, spread it around the tub to balance the load.
It is normal for the tub to shake during the spin cycle. The washer has a safety feature, if it is too badly out of balance it will shut itself down and sound an alarm.
Jun 01, 2014 | Whirlpool Refrigerators
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
Tub is off balance
The tub is out of balance. When it starts hitting the sides, stop the washer and move your clothes around inside the tub to balance the tub. Now start it to spin again. This should stop the tub from hitting the sides.
Feb 14, 2012 | GE Washing Machines
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Washer makes noise during spin cycle, sounds like tub is off balance whether clothes are in tub or it is empty.
It could be that your drive coupling is getting ready to puke. Mine did. I also had a part fail and drop between the washer tub and the housing that surrounds it- Made a hell of a noise when the washer was spinning. I fabricated a new part/assembly to fix it. All mass-manufactured products have the same flaws. Cause they are all the same! I own a Kenmore Elite- if you don't, this may not apply to your problem.
Feb 22, 2010 | Amana NAV3330AW Top Load Washer
Spinning is out of balance even when there are no clothes in the washer
Most has a balance ring built onto to the tub, make sure thr balance ring is not damaged, It is normal for the tub to shake in the spin cycle with nothing in washer
Dec 22, 2009 | Kenmore 22422 Top Load Washer
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Neptune washer tangles all cloths
the washer has a balance ring that hold water that is ok. as of the tangleing you may have a low water fill
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
