Question about Compaq Presario Notebook
Compaq presario v2000 overheating issues...
I've had my laptop for 2 years and have gone through 2 hard drives, presumably (according to the technician) due to overheating or 'bumping' it. i don't use my laptop as much more than a desktop so jarring is not likely the issue...i was wondering if anyone else has had similar issues with the v2000, or if this could be a fan issue, as seems to be fairly common...it has never shut down on me, but does at times feel quite hot...the fan turns on, but perhaps is not doing enough? thanks for the input
  • 1 more comment
  • Anonymous Aug 10, 2008
    I have the same problem and now my fan has completely quit working. I am in the process of seeing if I can replace the fan but, for now I have bought a cooling pad to place my laptop on in order to be able to use it. This is the worst computer I've ever owned!
  • Anonymous Sep 28, 2008
    It keep overheating and shutting off by it self.
  • Anonymous Dec 14, 2008
    my v2000 is also having the problem but i had heard that it was a problem with the thermal paste around the heat sink since the manufacture didn't apply any by placing thin metal sheet around it. if however they did then after 2 years it has completely dried up causing the cpu to overheat and shutdown. is there any instruction's to fixing the heat problem or applying the thermal paste to my laptop.
  • 26 Answers
Yes, this is a fairly common problem with the v200o, caused by a lack of good fan airflow. Your best bet in using it would be to get a laptop pad. This will not only keep your laptop cooler, it will prevent your legs from blocking the fans when it is on your lap.
Posted on May 08, 2008
Running home ed windows on presario v2000 (now five yrs old) windows loads but harddrive continues to run inefectually - cant access programmes etc - then screen turns blank after approx 20-30mins - hard...
Backup your programs immediately to a thumb drive or external HD. The hard drive may be on the brink of failing. You can replace a hard drive, it's your information thats on it that you may not be able to if it totally crashes!
Mar 20, 2010 | HP Compaq Presario V2000 Notebook
Hard drive compatibility with compaq presario v2000
Hi this hard drive will work with your laptop all it needs to be is to have a SATA connection cable
2.5 inch = laptop
3.5 inch = Computer
Hope this helps
Muzzi_123
Nov 14, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 laptop stuck on compaq logo screen
when turning on the system go into the BIOS and reset back the seeting s to factory defaults and reboot the system .. If this fails then reseat the Hard drive may have come loose or ?
did you recently add new software ? drivers ? hardware?
Oct 14, 2009 | HP Compaq Presario V2000 Notebook
Compaq presario v2000 wont reconize harddrive
check that the jumper on the hard drive is set the same as the old hard drive i.e master or slave.
Jan 03, 2009 | HP Compaq Presario V2000 Notebook
Hard drive not working
If you're sure about your issue, you can get one hard drive on the internet and replace it.
check here:
http://www.comptick.com/cq-c7sa-160.html
Oct 27, 2008 | HP Compaq Presario V2000 Notebook
MBR error
As I mentioned in your first post, it sounds like the hard drive has the problem.
Replace the hard drive.
Oct 18, 2008 | HP Compaq Presario V2000 Notebook
Drivers for HP Compaq Presario V2000 laptop
pls send compaq notebook presario v2000 audio driver
Jan 08, 2008 | HP Compaq Presario V2000 Notebook
Laptop
Here is the manual for your laptop.
Turn to page 118 for directions on how to change the hard drive.
Dec 30, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Operating system Problem.
you need to run hard scan on your Hard Drive ... it's obvious that a sector on your hard drive is corrupted
Dec 28, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario Notebook Logo
642 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
