Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Sync software/empty folder/ slow backup/
Dear IB4G20:
I've just bought LaCie External Desktop Hard Disk USB 2.0 500GB two days ago.
So far I have three problems with it:
1. The salesperson left me under impression that this product comes with a software that has a 'sync' feature as an option. What I understood is that suppose I backuped a document in LaCie. Then every time I make any changes in that document I could just click a backup button, and the LaCie software would sync my updated document with the previous one. So I don't have to do the replace procedure manually.
The software that came along with this product does not have such a feature. Moreover, it cannot even ask me whether I want to replace the existing file or not. It frivolously renames my file but putting some numbers in front of it. I really don't like it doing this.
Q: I wonder if LaCie provides any sync software that would be compatible with this hard disk?
2. I tried to backup my entire C drive (total 128 GB) of my laptop.. In more than 10 hours, the happy message came up telling me that the backup process was successfully completed with some minor errors. Then when I tried to open it to see what had been backupped, it showed that the folder was empty. So more than 10 hours for nothing. Moreover, when I try to delete it, it looks like the system is trying to delete a bunch of files (my entire C drive, I guess). So, the folder is not empty, but appears to be empty.
Q: How to make the data visible, not 'empty'?
3. My laptop is only 1 year old. it's Toshiba Satellite U205-5067, 2048MB DDR2 SDRAM, (5400RPM). Windows Vista. It runs pretty fast.
The backup process is slower than I expected.
Q: What could be a problem?
Best regards,
frustrated one
  • ann_hohisel May 11, 2010
    I did not see an answer to the second question about how to make the files show up in the folder and not look empty. I haven't been able to find an answer to that anywhere. Please note that I have already set my folder options to show any hidden files and I still can't see any files/folders. Any help will be appreciated.
    Genius:
  • 3,587 Answers
Hello frustrated one,
the back up feature is application dependent, not hardware dependent, misfortunately. Gotta love sales guys.
my understanding is that these will back up data files, not application files.
backup speed is dependent on how it's connected. in ascending order.
USB 2.0
Firewire
Ethernet
simple situation..just need to know what your connecting with.
Also, you may want to consider an online backup utility, as well. I use one from here
Posted on May 08, 2008
I've bought a new computer and want to use my Lacie 1tb with it, but its
Your details of this problem was not complete.
Please provide the details of your problem so I can assist you.
Apr 15, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Can i backup more than one computer on this hard drive?
Yes. Create one "folder" per computer, and copy files from one computer into one folder.
Oct 23, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
How do I read and work with files that were backed up on my external drive?
You have to run the "Recover" option of the software that was used to back up the data. The files are packed in a foreign format that has to be unpacked by the saving backup software. You should have an option to restore selected files to your working are on your hard disk drive.
Which software and version was used to backup the files?
Dec 08, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lost my data from my imac drive trying to backup to my Lacie.
yes U can recover it... plz download the registered version from the torrent site of software know as DATA DOCTOR RECOVERY .. this software will help you getting back you Data if you did not formated the Hard drive.. thank u for asking Question..
Jun 23, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie USB 2.0 No files or folders displayed in backup folder
Did you try showing "hidden folders and files"?
In the Explorer, select the Tools menu, and pick Folder Options.
Select the View tab and in the list enable "show hidden files and folders".
You can also try showing system files (so choose not to hide them).
That should show you all files and folders on the disk.
Do make sure you are logged in as a user with admin rights.
May 13, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Backup folder shows as empty
Have you tried showing hidden and system files?
In the Windows Explorer, go to the Tools menu and select Options or Folder Options.
In the View tab, scroll in the list and make sure show hidden files is selected. You can also unselect the 'hide system files' option.
That will show you anything on the disk!
Jules
Apr 02, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie hadr drive problem
Data recovery software.
Check this link:
http://www.software.com/view/8384/72/easeus-data-recovery-wizard-professional-4-x
Feb 06, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Creating space on external hard drive
When you move files to the Trash on a Mac you are just marking the files to be deleted next time you empty the trash. You are not actually deleting them when you move them to the trash. They will continue to take up space on your drive until you empty the trash.
Emptying the trash will delete everything in the Trash folder regardless of which drive it is stored on. If you have files you are not certain you want to delete that are located on your internal drive, open the Trash folder and move them temporarily out (like to the desk top), then empty the trash to delete all the ones on the external drive that you do want to clear off.
You will see that the free space has increased on the external drive. Now put back in the trash the files from your internatl drive you were thinking of deleting but not certain you wnated to (if that is your reason for not wanting to empty the trash. I'm not clear on why you would not want to delete them.)
Apr 04, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
495 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
