Question about Canon Office Equipment & Supplies
I replaced the drum and an error comes up that sayssystem error E071.
  • 3,640 Answers
Type worldoffax.com/errorcodes, a page will come up then click on world of faxes error codes and trouble shooting. everything should be right hear on this page.
Posted on Aug 30, 2010
Error E071 0007
A E071 deals with the transfer drum unit engaging unit. Has the transfer sheet been replaced lately? There is also a drive unit on the back side of the copier for lifting the transfer drum. There is a senor that may be dirty or damaged.
Dec 25, 2010 | Canon CLC 1140 Copier
Error Code: E071 0007
I got an error code on my canon clc 1100:
E071 0007
Aug 19, 2010 | Canon CLC 1110 Copier
Canon CLC900 error code EO71. Transfer problem? Is solution to replace transfer unit or will some cleaning suffice? Tim Matteson A-1 Business Machines mattesontim@ymail.com
A E071 deals with the transfer drum unit engaging unit. Has the transfer sheet been replaced lately? There is also a drive unit on the back side of the copier for lifting the transfer drum. There is a senor that may be dirty or damaged. Also, is the code a constant or will it show up when ever?
Aug 12, 2010 | Canon Office Equipment & Supplies
Canon color imageclass mf8180c, Iam getting '' SYSTEM ERROR E071
I had the same error message E071. Had to call out an engineer who diagnose the Drum 701 was leaking toner - this got on the electrical contacts at the bottom of the drum. He cleaned the contacts on the drum and in the machine - put my old Drum in there and all is OK. The drum was 9 months old and not had much use so I am trying to get a replacement from Canon under warantee.
Apr 06, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon ImageClass MF 8180c Error Code E071
i had the same problem, had to replace the drum unit
Mar 10, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Canon MF8180c
E071 error stands for ITB position sensor fault,so you may try to check if the ITB belt is ok, if there is no paper left overs or similar, but this error can occure when the main board ( dc controller ) is defective.
Nov 01, 2008 | Canon imageRUNNER C3200 Color Printer
Facing Problem in Canon Colour laser copier 1120
your a, b and c side sensors are bad they are found next to each other in the transfer drum
Sep 12, 2008 | Canon CLC 1120 Color Copier
I have a system error e071 on mf8180c image class.
Hi, as per the manual it says
E071 ITB home position sensor fault
Solution
Check the connector of the ITB home position sensor.
Replace the ITB home position sensor.
Replace the DC controller PCB.
Jul 25, 2008 | Office Equipment & Supplies
E071 0003
E-071 0003: There is an error in the rising edge timing of the signal plate detected by the C sensor.
The transfer drum isnt rotating or the machine "thinks" the drum isnt rotating. Check for mechanical interferance and check the drawer connectors for paper and debris
As for the guest with the E-803 error, thats not really the same thing at all. I guess both error codes have a "3" in it but thats about all.
E-803: During operation the CPU does not detect a 24V output for 5 sec while the transfer unit, the left door, and the delivery door are closed.
Check the aformentioned doors and switches but most likely it is the power cut relay that is faulty. The relay is located on the lower left hand side beside the main power supply. The relay contacts become pitted and burnt over time.
Apr 15, 2008 | Canon CLC 1120 Color Copier
88 people viewed this question
old marine
old marine
