Question about Ruud Heating & Cooling
Hi, After finding out that Freon is low by seeing snow/icy surface on outside compressor, I went up in the attic to find snowy/Icy surface all over the coil inside the air handler. I wahsed it and made sure all snowy/Icy surface is melted inside and ouside and Freon is full all the way. Now when I start yhe system fro the Thermostat, the compresor and outside unit start, but nut the fan inside the air handler, so no air is blowing inside the house. Where should I look for ? This is a RUUD 500 A/C unit Thanks Sam
  • zaghmoui Aug 30, 2010
    Unfortunately it didn't work. I did exactly as you have mentioned above. It looks like the air handler motor or Fan blower motor needs to be checked. Either capacitor or something else that made it come to a halt after being overwhelmingly worked up during the freezing up process due to lack of refrigerant outside. Your thoughts are very much appreciated !
    Genius:
  • 1,400 Answers
Hello
Your still froze up.There is a freeze cutoff device in the air handler upstairs.
Look for a thin silver color tube near the coil and follow it to the control box,there may be a reset button.If not, try using a hair dryer to warm up the coil and it should reset itsself.
These freeze devices can take an hour to reset on there own sometimes,do not run the compressor while doing this.
Posted on Aug 30, 2010
  • 6 more comments
    24 hours have passed since I melted the Ice and by now I am sure there is no ice or snow per say. It looks something needs to be reset manually ... I hope I could find what you are pointing to ... the thin silver color tube near the coil. The System is shut off for now !
  • mpcheesman1
    mpcheesman1 Aug 30, 2010
    24 hours?
    Try a manual reset,Shut down all power to the inside and outside units,throw the breakers off.
    Let it sit for a min or 2 then,with t stat set to off. Turn on power outside,then inside.
    Then set t stat to on,or where you had it before.
  • mpcheesman1
    24 hours?
  • mpcheesman1
    24 hours?
  • mpcheesman1
    24 hours?
  • mpcheesman1
    24 hours?
  • mpcheesman1
    24 hours?
  • mpcheesman1
    sry for the multiple replys, i dont know why that happend
Car sways when driving over rough surfaces, bumps in the road, man hole covers. HAS POOR TRACTION ON SNOWY/ICY ROAD CONDITIONS IN TURNS IT SWAYS AND FISHTAILS. hARD TO KEEP ON THE ROAD.
Sounds like you need new shocks all around for the Swaying & Rough Roads stuff.
As far as the Ice and snow try snow tires but you have to realize its a pretty big car and may not handle very well in the snow.
Nov 13, 2013 | 2004 Chevrolet Impala
What setting should the transmission be set to
For fair weather driving 2wheel should be fine. for muddy or snowy conditions turn it to all wheel drive for increase traction.
Apr 21, 2013 | 2004 Chevrolet TrailBlazer
ICV WARNING LIGHTS IS ON IN MY 2010 NISSAN MAXIMA
Are you check the Owners Manual ? This warning actually spells ICY... and it is an automatic indicator to warn of ICY roads and weather conditions.
The word ICY means that temperatures outside are near or below freezing. Its a warning for possible icy conditions on the road. Its a feature that comes with your trip computer along with the temperature gauge.
Hope this helps.
Dec 19, 2012 | Cars & Trucks
Should you disable the traction control on a 2006 Ford Explorer when driving on snowy roads at a speed of 35-40 mph?
the role of the Electronic Control System is to avoid wheel spinning on icy or 'snowed' surfaces. When the system that one wheel having traction is spinning faster than the others than it will apply brake to that particular wheel to help it to recover its traction.
In the reality, the system is more active when you are accelerating after a stop on icy surface. Once the vehicule got its speed the system should be less active .
Globally, this system should help to keep the traction at its best under any condition.
However, my personnal experience is that you could have to desactivate the system if you are driving in heavy snow condition. Under these particular conditions, the system could apply brakes to a point/frequency that your vehicule will run as a turtle.
In conclusion, there is nothing bad if you let the system manage by itself, unless you don't like the feeling or unless the system generates more problems than benefits.
Hope I have ansered your questionning.
Dan
Jan 06, 2010 | 2004 Honda Accord
How do you charge the rear a/c
THERE ISN'T 2 SEPERATE SYSTEM. ONLY ONE COMPRESSOR. YOU MAY HAVE A BAD EXPANSION VALVE OR BAD BLEND DOOR MOTOR IF NOT COLD IN REAR. IF FRONT IS COLD SYSTEM IS FINE ON REFRIGERANT. CONTROLS TO REAR PLENUM MAY NEED HELP. SEE IF TEMP CHANGES WITH REAR A/C TEMP CONTROL.
Jul 18, 2009 | 2004 Ford Freestar
Snow button on my 2008 Highlander
The "snow" button sets the transmission to start off in second gear, and makes the accelerator less sensitive thus reducing the tendency to slip and slide. It also has the effect of reducing the power and responsiveness of the car. Try driving with the snow button "off" in "normal" snowy conditions and see how you go. Use "snow" for exceptionally icy conditions.
Dec 27, 2008 | 2008 Toyota Highlander
Severe crunch sound with ABS system, plus ECS light goes on.
Good news,
Your noisy experience with your ABS and ECS is exactly what all of these systems do in icy, snowy, and any environment that causes your tires to lose traction. The ECS light when blinking or illuminated is just informing you that the ECS is being activated to let you know your traction is limited.
I have an Elantra and have driven my GF's '06 Sonata many times. I live in MN and it does the same thing with snow etc. and so has past cars i've owned such as Subaru Legacy, Pontiac Grand Prix, and Toyota Camry.
With ABS it does seem to take quite some distance to stop in icy or snowy conditions. When it's dry it's impossible to beat.
Dec 11, 2008 | 2006 Hyundai Sonata
Low traction light is on and i am not driving the car.
Most probably a wheel speed sensor. If you had a scanner you could run the codes and find which one, many time in wet and icy weather they will get a bad connection or the snow and ice get clogged up around them. I hope this helps you! Merry Christmas!
Nov 25, 2008 | 2001 Buick Century
Heating & Cooling Logo
76 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
