NO DISPLAY i have a problem with my computer, i have a motherboard msi p4m900m2.. it won't open and no dsplay boot..is it th...what should be the solution to solve this problem..plz help.....
  • Anonymous May 03, 2009
    Please help.. I have the same problem with display too. My motherboard has problem if I change the video card to PCI-E graphic card. If I use graphic card on board, it's no problem. It always restart when I used PCI-E graphic card (ATI Radeon X1550).
    My graphic card ATI Radeon X1550 PCI-E 256MB DDR2.
    Memory 2GHz @ DDR2 PC5300 1GHz
    I used 3 storage with IDE Cable & 1 DVD-RW with same IDE cable.
    Sergeant:
    Champion:
  • 304 Answers
Did you hear any beep sound, when you try to switch ON the computer..?
Thank you..
Posted on May 08, 2008
    President:
  • 2,351 Answers
Hi m_o_redz, please check you're power cord from you're monitor is connected & working. Than check the video cable from the monitor to the PC, good connections. (Replace if you have a spare). If you can hear you're system booting up, (fans are running, lights on case are flashing/coming on).
Than you're on board (VIA P4M900 VGA) is defective.
After checking everything above, suggest you use other graphics slot on you're board.
You have an opened PCI-Express x16 slot on you're board. Buy & install the PCI-E card into you're PC. You should receive video display & be able to enter you're bios to change from the onboard VGA graphics to PCI-E graphics card.
MSI is not listing you're current board model number. There is two other model number board & both are very similar.
Below are the two MSI links.
MSI P4M900M2-F / L
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=1123
MSI P4M900
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=1150
Here is a link for a PCI-E graphics card.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1560&name=256MB-PCI-Express-Video-Cards
Good Luck!
Have more questions? Please feel free to ask.
Mike
I can not download drivers for the ms 7255 msi motherboard from the msi website
The MS 7255 also known as the MSI P4M900M2-L
Here is the direct link to the MSI support page where you can download the drivers and manuals for you Motherboard.
Hope this helps! P4M900M2
Jun 19, 2014 | MSI Computers & Internet
Where can i download the vga driver of p4m900m2?
there is an F and L model go here and choose the correct board and you can download the driver http://www.msi.com/index.php?func=searchresult&keywords=p4m900m2
please take a moment to rate this solution thanks
robert
Nov 28, 2009 | Intel Motherboard
Audio driver of MSI P4M900M2 motherboard.
hello
May bee you looking for this?
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=1123
choose vista or xp and download the driver.
if its wrong driver use the driver guide to get the right drivers for your motherboard.
http://global.msi.com.tw/index.php?func=downloadindex
Oct 19, 2008 | Intel Motherboard
NO DISPLAY
If the motherboard still power on it. You can test it to identify where is the fault.
first remove the memory..if you use ad on video card then remove it. if it is built in then only the memory to be remove.
Power on/switch on the PC. If here any beeps then probably ..You rmotherboard is OK and the Processor. If not hear any beeps.. then, examine the processor and the motherboard..You can check the processor by inserting it to the other motherboard with thesame socket to your motherboard.
and motherboard can be determine if it fault tru seeing touching some chips which overheating. or by inserting other working processor in it.
If hear beeps on the PC, then insert the memory and then test..if not resolve then, remove the memory and clean with soft material or eraser. then insert it back, Again if not resolve time to replace the memory.
may this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 08, 2008 | Computers & Internet
NO DISPLAY
Hi m_o_redz,
If you are using the on-board (integrated video), S3 Graphics Chrome9 HC Integrated Graphics core. Than check you're video cable, video cable connection. Try another monitor. If all check out ok than the MSI integrated video is defective. Suggest you install a PCI-E video card.
If you are using a PCI-E card, try removing it. Clean the copper contacts using a cotton swab & alcohol. (Let it dry) Than reseat the PCI-E card.
Try booting again.
Good Luck!
Mike
Apr 22, 2008 | MSI P4M900M-L Motherboard
Cannot reset
hello,
I encountered that before, REstarting is not feasible.
Please refer to you manual about the power management. in the bios setup. try to see if there is red alert about low voltage.
Try to use another power supply that is good and match to your motherboard.
Hope this solve the issue., melnavz
PS:pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Open Questions:
Instant US''1-:877-:778-:89:-69''AVG Antivirus Tech Support Phone Number? 1-877-778-89-69 AVG Antivirus service phone number is solve the matter of virus's. 1-877-778-89-69 is loosely used in USA. It offer the ability of 24*7 services. AVG Antivirus customer care service number's executive able to solve the any virus problem with the assistance of AVG antivirus support phone number.It doesn't matter from wherever you and at what time you need help. For know about us:-1877+778+89+69 If you want to the best solution for your Antivirus problem you must call our technical phone number 1-877-778-89-69. Our technical experts suggest you to fast and easy way to protect your device. Just Dial Our TollFree Number 1-877-778-89-69 and get full protection for your device.In case of any Antivirus problem must dial our AVG Antivirus Support phone Number:1-877-778-89-69. AVG Antivirus Support Phone Number, AVG Antivirus Customer Service Phone Number, AVG Antivirus Tech Support Phone Number, AVG Antivirus support Helpline Number, AVG Customer support Telephone Number.AVG Helpdesk number,AVG Tech support Telephone number,AVG Security Tech Support Number,Free AVG Antivirus Customer Support Number,AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number.
May 29, 2017 | AVG Computers & Internet
Computers & Internet Logo
178 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
