Question about Epson Stylus NX400 InkJet Printer
Printer just says sending print data.. but nothing happens
5 Suggested Answers
SOURCE: I send a document from WORD (ms vista) and nothing
Vista has most drivers, and certainly supports your printer.
Try this routine.
First turn on your computer.
Now, turn on printer, and connect the USB.
Vista will recognize it.
i) Go to printers and faxes and set your printer as default, because there are other software like One note which could be default.
OR ii) Go to your word document, ctrl+P for print settings, choose your printer from the drop down menu
Posted on Jun 03, 2009
SOURCE: I send a print job to the printer and nothing happens
try downloading the latest print driver from www.kyocera.com or www.mita.com you may have a corrupt driver or it may be incompatable with an update
Posted on Aug 05, 2009
anantakumarj
  • 330 Answers
SOURCE: Canon i9900 - have to restart every time in order to print
reinstall the printer driver and restart the printer spooler service also . make sure that c drive have more then 3GB memory to run the services .......
Posted on Oct 23, 2009
SOURCE: The printer won't print. There's a solid red dot
the head in jam so u have to check that the head is working properly or not .
Posted on Jun 11, 2010
Linux O/S, driver installed. Reports data sending to Printer, then says printing complete. Nothings comes out of the printer; test pages won't print.
Is this a new problem or did it once work and now something's changed, please?
If it prints from your other computer, what happens if you delete then reinstall the drivers on the suspect computer?
May 07, 2016 | Office Equipment & Supplies
How can I get my mac to communicate with my printer?
reinstall the printer driver from the manufacturers web site as a lack of communication indicates a driver problem
next click on the printer > properties>compatibility tab> click box and highlight operating system on the computer and >apply
Jul 24, 2017 | Epson Workforce 615 AllInOne Printer
Hello. I have a Deskjet 810C, and a friend tried to adjust the settings. Now, when I try to print one full page of a document, it only prints a jumbled portion of one line. After that, it feeds through...
The symptoms indicate that the printer is receiving a data stream that it does not support or the data stream it is expecting (is set for) is not the one it is receiving. This also happens when the printer is somehow disrupted (like momentary power off) during printing. When it resumes, the setup information sent previously for the document has been lost, but the computer doesn't know about it so it sends data to the printer which prints merrily on in gibberish.
If you haven't already done so, try turning the printer off, disconnect the power cord for about 5-10 seconds, replug and turn the printer back on. Check to see whether that resolves the print issues.
If not, run the diagnostics: with the printer already on, press and hold the power switch while pressing the Resume switch four times, then release the power switch. If the problem is internal to the printer, nothing will happen (internal diagnostics should run and the printer will print something).
Assuming the diagnostics ran ok, the fastest way to fix this type of problem is to reinstall the printer drivers and software. Something has probably happened to the driver or the installation which is easiest to counter by reinstalling.
Mar 07, 2011 | HP DeskJet 810c InkJet Printer
Not printing
If you send a format and the label advances but does not print, then it is possible that the darkness setting is not high enough for the label/ribbon combination. Depending on what software / printer driver you are using, many times the darkness setting in the software or driver will override what is in the printer. This makes it possible to have the test print work just fine but no printing when a label format is sent the printer.
If you are sending a format and nothing at all happens at the printer, then that is a communication issue. How are you connecting the PC to the printer ?
Apr 19, 2010 | Datamax I-4308 Thermal Label Printer
Oct 23, 2009 | Canon i9900 InkJet Photo Printer
My Stylus C66 won't work.
You have to replace all ink cartridges, it is somekind selling trick. I have epson printer too and it wont work if you replace just one ink, and i have 6 ink cartridges :D
Jul 06, 2009 | Epson CX8400 All-In-One InkJet Printer
Jun 11, 2009 | Office Equipment & Supplies
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
HP psc 1210 will not print
Please check the printer status at control panel printer properties if it is offline or ready. Restart your computer if necessary, you will notice all pending jobs will be printed as long as there is no problem with the connections of cables and drivers. Note: Do not cancel printing jobs in the middle of sending data mode to printer or queing instead you have to remove all papers on tray and wait for the error "paper out or empty" then there click Cancel. Hopes this helps.
Best regards,
Rosener Guyano
Feb 02, 2008 | HP PSC 1210 All-In-One InkJet Printer
SRP-350 barcode CODE 128 C printing problem
I have a samsung printer srp-350pg, it is printing garbiches, I download a driver does the samething, used generic driver but nothing changed
Please help
Mar 28, 2007 | Samsung SRP 350 Thermal Printer
Epson Stylus NX400 InkJet Printer Logo
241 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
