I own a midea top loader washing machine MQB80-700B and i have lost the instruction manual. The machine won't spin to drain and i'm not sure where the filter is to check it. Could you please let me know where it is?
gittos73
  • 244 Answers
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Posted on Sep 12, 2007
onthejob5130
  • 640 Answers
SOURCE: maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Posted on Jan 03, 2009
tunde007
  • 2382 Answers
SOURCE: I have a Midea 8kg Top Load washer, Model number:
Hi, the E2 error means you are having a problem with the lid swiych. If the washer fills normally, runs through the wash cycle, then stops at the spin cycle and won't drain, then you need to check your lid switch and/or lid strike.
This is the most common cause of the problem you just described. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
Posted on Feb 06, 2011
jumptrout51
  • 3361 Answers
SOURCE: My maytag washer will fill up with water but not start washing
Replace your lid switch.
Posted on Mar 08, 2009
SOURCE: Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Door locked light flashes.
After turning off at power point, then restarting unit will commence but light starts flashing again and machine stops
Posted on Jul 04, 2010
MIDEA WASHING MACHINE INSTRUCTION MANUAL FOR MAE00-S2002GPS
Are you sure about the model number? I found an MAE100-S2002GPS washer on the Midea site. Go to http://www.midea.com/us/consumer/washing_machine/fully_auto/201404/t20140401_81499.shtml and click on the support tab for the manual. The direct link is http://img1.midea.com/us/Local_Library/info_instructions/washing_machine/fully_auto/201606/P020160614194954149229.pdf .
I hope this helps.
Sep 02, 2016 | Washing Machines
Midea washing machine not spin/draining
The drain may have been clogged with something else.
Nov 25, 2013 | Washing Machines
I have a 5 year old Midea aw60-982 washing
Sounds like a bad belt or a locked up pump.
Sep 16, 2013 | Washing Machines
Ge prodigy top loader wash machine. washes fine, spins, but water won't drain. have checked for blockage in hose and found none. water will trickle through hose then stop. what do I do? Don't...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 22, 2011 | Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
I have midea AW60 9906 top loaded washing machine and i lost its manual
If you type into your search engine 'midea aw60 manual' you should be presented with a number of sources from where you can either download free or pay. At some point you will be asked for the other number.
Hope this helps.
John C
Feb 07, 2011 | Washing Machines
My ge front end loader washer won`t spin water or pump water out
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
Please help me with my washer
Hello browneyez070
Welcome,
You said, your Hotpoint top loader washing machine won't spin water out. Model VBXR1O6OVOWW?
Common causes before considering repairs.
Water won’t drain
Drain hose is kinked or
Improperly connected on it.
Solutions
• Top of drain outlet should be less than 8 ft. above floor.
• Straighten drain hose and make sure washer is not sitting
Let me know if these measures help.
Huuum
Oct 15, 2008 | Hotpoint VBXR1090B Top Load Washer
Water drains in wash cycle
It is probably a solenoid valve for the drain that is stuck open. There could be an object in it or may be defective.
Jun 12, 2008 | Washing Machines
Washing Machines Logo
402 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
