The way to insert them is like follows..
The semicircle one will fit first in the location ...and pay attention to insert it in the right way ...there will be another semicircle piece inside that it is not removable ..and they have to kinda complete themselves..after that you put in place the ring like cover to keep it in place ...For some machines this is door like action ..having a hinge and a snap lock ..for others is removable and it has a screw..
once all these in place ..(do not force them when you locate the right position it will fit gently ..and usually you hear a click...all you have to do is to move that semicircle a little until it fits in place..and cover it up with the lit circle..)
the lat piece will be the bobbin ..with the case on ..and the thread passed by the slot ..in its position ...
this one also have to snap in ..when you get the right position ..the Idea is to put it on the site ...and rotate a little the wheel to make it fit..and snap ...when you hear the snap you are sure that it is in the correct way and will not pop out when you rotate the wheel
Thank you, think you were describing a newer machine than I have but I figured it out. Any worry that "lost needle" might cause damage? (Than again, may find that lost needle under the bed one of these days, ha)
Also, cannot use feed dog lowering mechanism. Looking carefully at parts that might be involved in the mechanics of the movement--well, just not clear how it works. Machine is a New Home DX2030, very basic and 18 year machine.
Feed dog lowering mechanism is a plastic lever activated by a toggle switch on rear of the removable sewing arm cover. Looks to me like the plastic lever should nestle against some mechanical part that holds feeds dogs in downmost position--but can't see where that might be!!
Needle fell out on its own when I was moving machine. Ha!
