Question about Car Audio & Video
While im driving, the radio will turn on and off, and it also cause my power windows not to work. I replaced my radio and the wiring harnest, but the problem still wont stop.
    Problem Solver:
  • 14 Answers
This is not a problem with the radio. If the problem affects the radio and power windows, it is most likely an electronic control board that runs both circuits. Chances are other circuits are affected as well, like wipers, internal light, cigarrette lighter, blinkers etc. It all depends on your car make, model and year. Please check functionality of all other items when this happens then post again with your car year, make and model.
Posted on Aug 30, 2010
2005 chevy cavalier after market radio has no power, im installing a pioneer head unit in my car, i bought a wairing harness connected it to the wiring harness for the new radio, im getting power to the...
No, make sure the vehicle key is in the aux or on position. If this still doesn't work, recheck the wiring. Also, make sure you have a good ground.
Sep 03, 2011 | Car Audio & Video
Trying to hook up stereo with out harnest need to know what the pink and black wire labeled audio interrupt needs to be hooked up 2 is this why i have power but no sound im puting the deck in a 1999 ford...
Ok, before you do anything else. STOP!! You can try to find the vehicle side of the harness from the Scosche or PAC website. You run the risk of frying your entire electrical system. Hope this helps.
Aug 20, 2011 | Alpine Car Audio & Video
I OWN A 1998 BUICK REGAL AN THE WINDOWS AN RADIO STOPED WORKING OUT OF THE BLUE, I BELIEVE THERE IS A SHORT BECASUE OCCASIONALLY THE WINDOWS AN RADIO WOULD STOP WORKING AN THEN WORK AGAIN, WE HAVE CHECKED...
I am going to explain something rather weird and some people will even say what's the difference. In your case it would be all thwe difference in the world. A "short" in a car will cause fuses to blow. An intermittent open in a car will cause things to operate only when they gt power. You have an open. There are more things wrong with the car you just haven't noticed them. The accessory position on your key feeds several spots on your fuse panel and in some cases is even split to feed multiple spots on the fuse panel. Take a piece of wire and run it from your battery positive to your radion fuse on the radio side. Pull the radion fuse, turn on the key, and check which side of the fuse socket has power. The one that doesn't is the radio side. Pu the wire there. radio should start working now. Cut this wire. The next time your radio dies, tie this wire together to see if the radio comes back on. Start there.
May 14, 2011 | Buick Regal Cars & Trucks
Stereo wiring diagram for 91 rodeo
i you need is the wiring harnest from walmart, wire up the same colors on back of the head unit to the new harnest, then slap the new harnest to the factory harnest DONT CUT THE FACTORY HARNEST, WILL CAUSE YOU A BIG HEAD ACHE but crutchfield gives out free step by step diagrams
May 01, 2010 | Car Audio & Video
Wiring harnest diagram
I provide wiring diagrams on a private website for a fee, let me know if you're interested
Oct 14, 2009 | 1994 Oldsmobile Cutlass Supreme
I have a 1990 oldsmobile 98 and i put an aftermarket cd playerin it I bought the wire harness and dash kit and i hooked it up and everything is powered up ok the problem im having is im not getting sound...
did you have sound with old radio before ? did you use a wiring harnest ? check speaker wires or if you have the factory bose or concert sound system the factory amp probably went bad therefor you would have to run speaker wire from each speaker to correct the problem .
reach me @ facebook Bret Hatfield
Jul 17, 2009 | 1990 Oldsmobile Ninety Eight
My windows and my radio stop workig at the same time!!
Sounds like you could have an issue with a connector going into your BCM or possibly your BCM itself. There is a fusible link that comes off the BCM and it goes to your radio and power windows. Off hand i believe its circuit 75 if you have a wiring diagram and possibly a dark blue wire. On the passenger side kicker panel there is your BCM you can try to wiggle the connector and see if that is it or inside the BCM the solder joints could be going and in that case your screwed.
Jun 11, 2009 | 1998 Pontiac Firebird
Car dies when driving at night
when alternator warmed up it would not put out proper amps. replaced and works fine.
Oct 20, 2008 | 2000 Toyota Celica
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
