Question about Food Mixers
Hobart H600 bowl wheel slips
I saw all of your excellent help to other Hobart users and thought you might be able to help out a friend of mine who has a H600 mixer. It works fine, but when he turns the wheel to raise the bowl, when he lets go of the wheel is goes back down on its own. Any ideas what parts we need to replace?
Thanks!
    Scholar:
  • 68 Answers
Some of the older H600s do not have a bowl lift lock. Look to page 18, items 57-72.
http://www.hobartlink.com/Extranet/ExtranetManualsAndCatalogs.nsf/6E1A88214EC64B59852568E1006A99F9/$File/F18797%20Rev%20B_lk.pdf
Take off the cover and see if the assembly is there. If not, get a bungee cord for the handle. If it is, when you start the mixer the solenoid should fire and lock the gears in place.
If the assembly is there and not working, check the it is not binding. If it is, free the assembly up and check the solenoid. If it was frozen it usually causes the solenoid to overheat and burn out. Good luck - Mike
Posted on May 10, 2008
What is the difference between a H800 and L800 mixer
I have used the H600. Nice piece of kitchen kit for hard use.
Model H600 is a heavy-duty 60-quart mixer which features a two-horsepower motor, a timer and a #12
Attachment Hub as standard equipment. With the use of bowl adapters and special agitators, 30- or 40-
quart bowls may be used on the H600.
Model L800 is a medium-duty 80-quart mixer designed primarily for use in general kitchen applications.
This mixer features a timer and #12 Attachment Hub as standard equipment and is powered by a
two-horsepower motor. With the use of bowl adapters and special agitators, 30-, 40- or 60- quart bowls
may be used on the L800.
A Bowl Guard is standard equipment on all H600 and L800 models.
A programmable timer controller is optional on H600 and L800 models.
These mixers can be ordered with a stainless steel finish.
A variety of attachments and accessories are available for all mixers. These are described in a separate Use and Applications Handbook, which is furnished with each mixer.
Here is your manual.
http://www.cvrsupply.com/manuals/hobart/Hobart_L800_Manual.pdf
May 07, 2016 | Food Mixers
What oil can you use for the hobart h600
on the hobart h600 we use 120 oz of 140 weight gear oil.
Mar 04, 2011 | Hobart H600 Stand Mixer
Our hobart HL 600,no display in speed and timer,even there a 24vac,supply in timer controller,only bowl up and down are working
If you have 24 VAC to the timer board and still have no display, then you need a new timer board.
Aug 02, 2010 | Hobart H600 Stand Mixer
Bowl Lift Nut H 6001
At your local Hobart office.
www.hobartservice.com Click on "locate an office" and enter your zip.
Jul 30, 2010 | Hobart H600 Stand Mixer
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
The handle on my h600 that raises and lowers the bowl broke off. Where can I find a new one?
call hobart, give them the info off the name plate and they will mail you one.
Jul 19, 2009 | Hobart Food Mixers
Hobart 600 wiring connection
The ground wire attaches to the ground lug under the top.
Mar 16, 2009 | Hobart H600 Stand Mixer
90quartmixer gears dont have power belt torn
Is the model an M802?Did the belt break or slipping?I'm a hobart tech,let me know.
Mar 03, 2009 | Hobart H600 Stand Mixer
Motor is burned out
Are you sure the motor is bad?
Dec 03, 2008 | Hobart H600 Stand Mixer
H-600 Turn Handle slips, bowl does not go back down
Does the handle seem to move easier?there is a shear pin on the handle and if it breaks the bowl wont move.Another thing to check is remove the silver plateon the front of the mixer there are 2 possibly 4 screws,when you remove this plate you will see a long screw about 3 feet long.turn the handle if the screw doesnt turn that pin may be broken.let me know.
Mar 18, 2008 | Hobart H600 Stand Mixer
Food Mixers Logo
150 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
